Same FPS on low and high settings
so since its free just downloaded watchdogs 2. While iam playing i always get about 50 fps no matter what on low or ultra settings. Radeon software says cpu usage is around 70 percent while gpu is 50-60. i have rx 5700 xt with an i7 6700k is it a bottlenecking issue? And any idea how to fix it?
Are you running single-channel memory and/or VSync?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
Sounds like you accidentally capped your fps somewhere.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
i have 8x2 ram and no v sync.
