Corsair RGB Hub to Hub JCORSAIR1 header
Solved by thrasher_565,
5 hours ago, JoNNyTwitch said:Hey, so I'm planing to buy 3 more of the Corsair LL140 RGB fans.
My Problem:I only have one JCORSAIR1 header on my mainboard and the Corsair RGB Hub only has 6 outputs.
4 are already in use and I need 3 more for the new fans.
Is there a JCORSAIR hub solution or a corsair splitter solution?
Does it work when I solder a splitter cable for JCORSAIR myself?
