monitor color setting question
reowin
this is this monitor i have
https://www.amazon.com/HP-23-8-inch-Adjustment-Speakers-VH240a/dp/B072M34RQC?ref_=Oct_BSellerC_1292115011_1&pf_rd_p=13743fce-caef-55ae-adb7-0dfa34cf0310&pf_rd_s=merchandised-search-10&pf_rd_t=101&pf_rd_i=1292115011&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=VSJ0MCHDH7083MY3DHWV&pf_rd_r=VSJ0MCHDH7083MY3DHWV&pf_rd_p=13743fce-caef-55ae-adb7-0dfa34cf0310
it has these color settings low blue light/warm/neutral/cool/custom setting
which should i be using to get the actual color im supposed to be getting?
ive been using neutral since i dont know what it should be on but im not sure if this is the correct setting for what i want
should i use neutral color setting on my monitor or custom rgb all at 265
To really get most accurate colour you have to get or borrow a device to calibrate it.
Second best ting you can do is to find some review that did calibrate it and see what settings they use, but will never get perfect as each monitor isn't exactly the same.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
