Search In
  • More options...
Find results that contain...
Find results in...
BlueScope819
What air cooler would you recommend with cooling preformance between a 212 and a NH-U12s?
Recommended Posts
Posted · Original PosterOP
The title. I'm not looking to spend any more than $60, because at that point I can just buy the Noctua cooler. Just looking for a quiet, good looking, cooler that could run something like a 3900x at stock speeds without issue.
@BlueScope819 so I can see your post
#MuricaParrotGang
"My name is Legion 'Murica Parrot Gang, for we are many."
Mentioned in 8/5/2020 TechLinked
The Gelid Phantom Black is a decent choice, not sure if it’s only available in the UK though. Also maybe try the esports Duo 34?
5Head :wine_glass: AH YES
imo at that point he's better off with the standard freezer 34 + another fan.
60usd -> thermalright true spirit 140 power. SIlent, powerful, tall, badass
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
Also it’s just as good if not better than D15. For 50 usd.
3770K @ 4600MHz 1.265v/Thermalright True Spirit 140 Power TY-143 Push/Pull
ASRock Z77 OC Formula|12GB G.Skill Mix @ 933MHz 9-10-9-28-2T 1.6v
EVGA GTX 980 Classified 3988 @ 1497/2001|Intel 545S 256 Striped
CM Silent Pro M2 850|Fractal Define R4/5x 120x38 1x 92x38|ZM-MFC2
To give solid recommendations i need to know what case its going into. If the cooler does fit it doesn't matter.
