XLR Mic too quiet with Audio interface unless I'm 5cm from mic
Astroflash
This is driving me nuts because I'm not sure how everyone else using XLR setups is surviving as I'm not using anything fancy. Unless I speak about 5cm away from the mic, the level is really low (about -30db) and my friends complain that 200% volume in Discord is barely loud enough.
 I've tried two different audio Interfaces ( Steinberg UR22C and Focusrite Scarlett 4i4 Gen3) with both a Behringer XM8500 (Dynamic mic) and an AT2010 (Condenser/Phantom mic) yet the level is still super low.
The mic is as close as can be to my mouth while being on the desk (About 20cm). The gain dials are at about 90% on both the 4i4 and the UR22C. If I go beyond that, there is a huge amount of audible white noise / (noise floor?) coming from the interface. Yes, the the recording level is set to maximum in Windows.
What is happening here? Why do both interfaces have such weak pre-amps?
I have a cheapo XLR mic, what I have noticed that you need a preamp for the sound level to be high enough.
Also, if you have a cardioid mic, is it oriented right? i remember my audio was shit because I ha d the microphone backwards (yes I'm an idiot)
Main PC [The Rig of Theseus]:
CPU: i5-8600K @ 5.0 GHz | GPU: GTX 1660 | RAM: 16 GB DDR4 3000 MHz | Case: Lian Li PC-O11 Dynamic | PSU: Corsair RM 650i | SSD: Corsair MP510 480 GB |  HDD: 2x 6 TB WD Red| Motherboard: Gigabyte Z390 Aorus Pro | OS: Windows 11 Pro for Workstations
Secondary PC [Why did I bother]:
CPU: AMD Athlon 3000G | GPU: Vega 3 iGPU | RAM: 8 GB DDR4 3000 MHz | Case: Corsair 88R | PSU: Corsair VS 650 | SSD: WD Green M.2 SATA 120 GB | Motherboard: MSI A320M-A PRO MAX | OS: Windows 11 Pro for Workstations
Server [Solution in search of a problem]:
Model: HP DL360e Gen8 | CPU: 1x Xeon E5-2430L v1 | RAM: 12 GB DDR3 1066 MHz | SSD: Kingston A400 120 GB | OS: VMware ESXi 7
Server 2 electric boogaloo [A waste of electricity]:
Model: intel NUC NUC5CPYH | CPU: Celeron N3050 | RAM: 2GB DDR3L 1600 MHz | SSD: Kingston UV400 120 GB | OS: Debian Bullseye
Laptop:
Model: ThinkBook 14 Gen 2 AMD | CPU: Ryzen 7 4700U | RAM: 16 GB DDR4 3200 MHz | OS: Windows 11 Pro
Photography:
Cameras:
Full Frame digital: Sony α7
APS-C digital: Sony α100
Medium Format Film: Kodak Junior SIX-20
35mm Film:
Lenses:
Sony SAL-1870 18-70mm ƒ/3.5-5.6
Sony SAL-75300 75-300mm ƒ/4.5-5.6
Meike MK-50mm ƒ/1.7
PSA: No, I didn't waste all that money on computers, (except the main one) my server cost $40, the intel NUC was my old PC (although then it had 8GB of ram, I gave the bigger stick of ram to a person who really needed it), my laptop is used and the second PC is really cheap.
I like tinkering with computers and have a personal hatred towards phones and everything they represent (I daily drive an iPhone 7, or a 6, depends on which one works that day)
The Behringer XM8500 has a sensitivity of -70 dBV for 1 Pa SPL, the AT2010 has a sensitivity of -48 dBV for 1 Pa SPL. So the AT2010 should be 28 dB louder than the XM8500 for the same distance and gain settings.
Yes it's correctly orientated. I don't get why I need to splash out for a pre-amp when an audio interface is literally designed to work with microphones.
Keep in mind that some mics are just designed that way. To only pickup very close audio and ignore everything around you.
I think jaze2cents had a video about just that.
It's definitely louder, but still a problem. I think the problem is I've gone for two mics which are both designed to be used right next to the mic. Looking at some other ones like the AT2020 they appear to be significantly more sensitive if I'm reading the specs correctly.
the 2010 and 8500 are both designed to be used with you right up close to the mic but having said that they should still work fine if you're a little away from it.
What are you using to test your levels? If you're just using the 'listen to this device' thing in windows, yeah, the volume is going to be low, mine is low too but games and Discord boost that to a usable level automatically. If you're recording the mics to test volume, yeah, you boost mics in post to fit them in a mix so it's not really an issue there. If that's all that's happening I'm not quite sure that anything is wrong.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
I'm using Ableton, looks to be about -30db peak.
I wouldn't have chosen either of those mics for audio production and I generally advise people purchase an inline preamp (like the Klark Teknik CT1) when using dynamic mics like the 8500 to boost gain.
Having said that, I just opened Ableton and tested for myself, my daily driver discord/gaming mic sits around -30 or so for spoken word at about 15 CM away in a normal to loud voice so there's not much wrong there. From what I can tell everything is working exactly as designed. Remember that unity gain (0) is where your audio will peak so the aim isn't actually to be at 0, it's to be at a reasonable level below that.
@rice guru
