Desktop and taskbar taking long to load and after loading simple refresh on desktop again takes longer.
Solved by Nishant Kumar,
I agree with @Jinu. You should try safemode or clean boot your computer to diagnose whether it is a hardware issue or a software issue. If your computer works fine in safemode or in cleanboot then you should turn on the startup services and applications one by one to check which is causing the problem. If your computer acts the same in safemode then it could be a hardware conflicting issue.
