Normal RPM for air cooler?
Mando772004
i have a gigabyte atc800 rgb cooler which cools my cpu very very well i have fantastic temps while gaming and while putting load on the cpu but  i notice its a bit loud so i checked the rpm on HWMONITOR and idk if this is high or low rpm so can someone tell me. my temps while gaming are 60-75 mostly in the low 60's. also since its loud i would like a suggestion on how to adjust it because like i said its a bit loud.image.png.3ae9626d7a702417b38d91743c957c17.png
Your temps are great, so you should go into the BIOS and reduce the CPU fan speed
Primary PC:
alright. can you tell me a specific rpm number that wouldnt be loud and still give me good temps? thank you!
Can't, all fans are different. You should experiment, see what you like best.
Primary PC:
alright thanks for your help!
The fans max rpms are different. So is how much noise they make. For example my CPU fans go up to 1600rpm, but I've limited them to about 1400rpm. 1300rpm is bit low if that really is max speed for the fans.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
