Search In
  • More options...
Find results that contain...
Find results in...
PeterCasteli
Does a dedicated sound card bypass the built-in sound card?
Recommended Posts
Posted · Original PosterOP
So I just got a new headphone with mic for gaming, but the mic doesn't record sounds very well. Assuming this is a motherboard issue and not a Windows issue, will it go away if I buy a sound card and plug the headphone in it? In other words, does a dedicated sound card bypass a faulty motherboard's sound card?
Yes, it does. But I highly doubt its a motherboard issue... I have literally never heard of a sound hardware issue.
I would be much more likely to blame windows or some settings than to blame the mobo.
Rig: i9 9900k @ 5Ghz - - Z390 Auros Elite  - - EVGA RTX 2080 XC Ultra @ 2025Mhz - - 4x8GB Vengeance Pro 3000Mhz @ 3600MHz - - Samsung 950 Pro 512 NVMe Boot + Main Programs - - Samsung 830 Pro 256 RAID 0 Lightroom + Photo work - - WD Blue 1 TB SSD for Games - - Corsair RM650i - - Sound BlasterX EA-5 - - EK Supremacy Evo - - XT45 X-Flow 420 + UT60 280 rads - - EK Full Cover GPU Block - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - Steel Series QcK XXL
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: ESXi 6.5 - - 250 GB SSD for VM's/ESXi boot - - FreeNAS 11.3-U2 - - HPE Proliant ML10 Gen 9 backbone - - i3 6100 - - 28 GB ECC - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander
White Lightning (original full watercooled build) - Homelab / Media Server - The Blue Beast (my car and other expensive hobby...) - iPhone Xs - 2018 MacBook Air
Yes. You would plug your headset/speakers and microphone into the dedicated sound card therefore bypassing the onboard sound card entirely.
Honestly I have a feeling it's your mic. Not gonna lie, but most of the time the mics on those 3.5mm headsets have potato sound quality.
AMD Phenom™ II X6 1100T @ 4.0GHz | MSI 890FXA-GD65 | MSI GTX 550Ti | 16GB Kingston DDR3 | Samsung 850 EVO 250GB | WD 750GB | Antec 300 | ASUS Xonar DG | Corsair A50 | OCZ 600W | Windows 10 Pro
Sony MDR-V250 | Logitech G610 Orion Brown | Logitech G402
Intel Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 8GB DDR4 | Windows 10 Home | ASUS Vivobook 15
Intel Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance DDR3 | Samsung 850 EVO 250GB | macOS Catalina  Lenovo IdeaPad P580
AMD Phenom™ II X2 550 @ 3.10GHz | Gigabyte GA-MA785GM-US2H | XFX Radeon HD 4870 | 4GB Corsair XMS2 | WD 250GB | Thermaltake TR2 500W | Windows 10 Pro
iPhone 6s (iOS 13.4.1) | iPad Mini (iOS 9.3.5) | Samsung Galaxy S5e
Only if you turn it off entirely.
I'd suggest buying a USB headset if you wish to bypass the onboard audio rather than an expansion card. Most Realtek audio chips are just the cheapest of the cheap, and occasionally they have issues where an OEM driver update breaks the chip, thus you end up with the wrong "ports" being mapped.
You may simply have to install the OEM software and when the box pops up "what device did you plug in" select microphone, otherwise it may default to line-in and that's why the input is too low.
Yeah I thought it was a Windows problem too, so I contacted them and they even did a remote access to my pc but there was nothing wrong with the settings. I don't now if I should reach out to Realtek or just buy a dedicated sound card.
19 hours ago, FlpDaMattress said:
Before you go throwing money at the problem, Try using another mic in the same port first, soundcards in 2020 are a hard sell.
I tried other mics but they all had the same problem
But every other mic I tried on my pc had the exact same problem
Might as well get an external DAC/amp unit if you have the desk space. Way better than a soundcard.
You can find USB microphones under $50 all day, I personally daily drive a CAD U37. It's a bit expensive on Amazon now, But goes on sale all the time. I picked mine up for $35, been rock solid for a few years now.
