Search In
  • More options...
Find results that contain...
Find results in...
Jobeello
Audio issue on My gigabyte aorus z390 pro wifi
Recommended Posts
Posted · Original PosterOP
Hi,
So long story short I got the audio to work but once I moved houses and set up my PC the audio is gone again. I reinstalled windows hoping I can fix the problem like I did the last time. I was able to go into realtek audio console and change my speakers to a "7.1 speaker" and when I run a sound test. I can hear half the speakers that light up on the realtek audio console software. I can also move the audio levels up/down and it'll make "ding" or if something gets plugged in i hear a "ding". Now it's partially working but i can't hear any sound off google chrome or anything else for that matter. I can only hear system notifications.
Things I've done:
install latest audio driver off Gigabyte, uninstalled all audio drivers then reinstalled the new driver again (rebooted), switched between speakers to realtek digital output in the bottom right corner. went in to sound control panel and messed with that ( bar moves if sound is playing, but can't hear the sound)
specs:
windows 10 64 bit
i7-9700k
gigabyte 1070
corsair 32gb ram
