Entry-level Ht Sound Recommendation?
wpirobotbuilder
I am looking for a sound setup which will run off audio from a Roku 2 or 3 (haven't picked out which one yet). The only constraint I can see is it needing to have an HDMI input with a video passthrough. Can anyone recommend a good entry-level sound system with this capability? 5.1 would be nice but not essential, 2.1 would be fine. Price range under $250 would be ideal.
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
do you have a receiver? you can hook up the Roku to the receiver and have the tv and speakers as output. you cant hook up speakers straight from the Roku
I don't, that's one of the components I'm looking for recommendations on.
receivers can get expensive. your budget is just enough for a quality receiver. if youre just lookin for connectivity, get the cheapest one you can find. Denon, Yamaha and Marantz are good brands.
i recommend these speakers
http://www.amazon.com/gp/product/B009IUIV4A/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B009IUIV4A&linkCode=as2&tag=wwwpuresimula-20
and this subwoofer
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-628
the two products dont have to be purchased from the sites i provided.
