Help with choosing right cooler?
Kiexli
I’ve recently done some searching about for a build, i’m new to building pcs, and I was curious what cpu cooler (preferably air) i should use if i’m going to oc a ryzen 5 3600 to around about 3.9, And preferably if someone could suggest a cooler that’s £100 or less that would handle that sort of oc
If your case has the clearance then Noctua all the way. NhD15 is massive but unrivalled in terms of performance.
If you wanna go for something slightly less pricey then NH U14S for a single tower cooler.
Hyper 212
Sycthe ninja 5
The stock cooler
Arctic Freezer 34 eSports Duo (less than 50)
Dark Rock Pro/ Dark Rock Slim is another option.
There is also a Noctua single fan model as well.
I found one that also looks promising, it’s the nactua NH-U12S, you reckon that’s good?
Scythe Ninja 5 is cheaper and better if you have the clearance. What case and RAM (specifically the model) are you using?
MAIN PC:
CPU: Intel® Core™ i9-9900K Processor  Motherboard: Gigabyte Z390 Aorus Pro Wifi  CPU Cooler: Scythe Fuma 2  GPU: EVGA RTX 3080 FTW3 Ultra  RAM: Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red  Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
SECONDARY PC:
CPU: Intel® Core™ i3-9100F Processor  Motherboard: ASRock Z390 Phantom Gaming 4-CB  CPU Cooler: Arctic Alpine 12 CO  GPU: EVGA RTX 3060 XC RAM: ADATA XPG 16GB (2x8GB) 2400Mhz CL16
Case: CyberpowerPC Onyxia  PSU: ATNG ATA-B 800w 80 Plus Bronze  Storage: 500GB Samsung 850 EVO + 2TB Seagate FireCuda SSHD 5400RPM    OS: Windows 10 Home
Former parts that I've used: Acer XG270HU, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti
I’m using 2x 8gb of corsair vengeance lpx and a cool master master box mb520
First, please hit the Quote button so that people can see when you reply to them.
Second, The Scythe Ninja 5 is compatible so I would get that.
MAIN PC:
SECONDARY PC:
3.9ghz isn't much. You can try the stock cooler first and decide on whether or not to replace it depending on the results.
