RTX 2070 hits the same temps even with fans on 100%
22 minutes ago, Stockholmes said:Yeah that's probably it. Tbh, I wouldn't worry about sub 80 degrees, sure having it cooler would be better but these things are specced to work at around 80-85c. If it bothers you, you could get a better cooler. How many fans does your cooler have / which model is your 2070?
https://www.gigabyte.com/Graphics-Card/GV-N207SGAMING-OC-8GC#kf
It's actually this 2070 Super, no idea why I put 2070. I tried taking the core and memory clock down 200 each and it made no difference, both hit about 75 within no time at all really. It's just the stock fans that come on the card. Just a little quieter and cooler would be nice but I guess I can always just put the PC under my desk for less noise.
I just feel like it should be way cooler really. I took the front and side of my case off and put all fans on 100% and then it stopped around 63-64. That's the only time I've been able to make even a bit of difference really.
