Best Way to Clean a Glass Side Panel?
Solved by TVwazhere,
5 hours ago, WaggishOhio383 said:However, that seems to have left behind residue from the cleaner drying. What's the best way to clean off the panel where it won't leave behind any smudges or residue?
Step 1: apply Glass cleaner.
Step 2: Wipe glass clean into glass with (preferably microfiber) towel)
You did both those steps, so what went wrong?
Step 3: Rewipe glass with a clean (preferably microfiber) towel a second time. This is to ensure you remove the leftover film that doesn't fully evaporate with the glass cleaner.
