My CPU cooler fan is revving like a car
AllergicBird
So lately my computer, which I built around a year ago is revving the CPU fan up like a car. I question if I am doing something wrong because I have not messed with any of the fan speed settings for anything on my PC. I just need some help I honestly do not know what is causing this issue at the moment, but from now on I will keep trouble shooting until I find a solution. (PC Parts in bio)
Check temperatures. HWinfo64 in sensor mode should give overwhelming number of thermal data
Desktop benching:
Ok thanks man I will try that I will get back to you gotta download cinebench
-> Moved to Air Cooling
Do you know which fan is being issue? Fans ramping means that they are adjusting to PC use. Without knowing which fan is being ramp up, you have hard time figuring out why fan curves are being issue.
The curves for GPU can be tweaked with MSI Afterburner, CPU and case fans with BIOS or motherboards own software. Or if that doesn't work, with 3rd party tools.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
