My pc cut power and restarts random !
RoTeA
Hello ! A few months ago i've buyed a pc from a site in my country like ebay ! All good ! After 1 month when i've palyed a game my pc  restart instantly ! Like a fall of electricity ! And then restart insead ! All good ! After some time pc do that again but more frequent ...... on a period i could not play any game more than 5 minutes because power cut off ! I've changed psu ! 2 month it worked good ! ....And now here i am i cannot play anything again ! This psu i ve bought it from a friend its old ... he its 450 w deluxe ! the first psu was atx 450w ! My pc strat up fast working whel on browsing etc .... when i enter in a game  after a few minutes power cut off and restart insead,but not all time , sometimes i can play 1 hour -2 hours with no power cut of ...  ! What should i do .......
PC SPECS :
Motherboard MSI H61M-P31 (G3)
Processor i5 3570 !
Ram 8 gb ddr 3 1333
Video Card SAPHIRE AMD R7 370
PSU 450 W  DELUXE !
It's possible to be something else to damage my psu? Or its about my house voltage problems, or psu its dead  !? I wanna buy something a bigger psu ! Recommend me pls ! Sorry for my bad english !
Stop buying questionable quality products and get a decent 450W.
"DELUXE!" is not a brand name.
Can you post a picture of the PSU label, if only to satisfy my morbid curiosity?
LOL!  Yeah....
That PSU is all kinds of awful.
230V input only.  Only 19A on the +12V (that's 228 WATTS!!!!)
That's one of the worse power supplies I've seen in a long time.
Suggest me a power supply bro
6 minutes ago, jonnyGURU said:
LOL!  Yeah....
Suggest me a psu bro
What country are you in?
What are some links to stores that sell computer hardware where you live?
Oh, it is, they make literal bombs, or at least rebrand them, usually these are bundled with the 20$ cases.
Tag or quote me so i see your reply
corsair cx 550w
thermaltake bronze
Antec Edge TruePower Classic
BR ONE Rainbow
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
You know what I meant.  😉
It's a "brand", but it's not reputable.
