Search In
  • More options...
Find results that contain...
Find results in...
Yashiees
Is there a problem with my settings or my pc?
Recommended Posts
Posted · Original PosterOP
Whenever I turn my screen or do little screen movements it doesn't seem smooth.
144hz monitor with rtx 2060
these are my settings
Not just on call of duty, but on other games.
Is it a G-sync or Freesync monitor? If so enable the option, if its enabled try disabling. Try a clean install of chipset and graphics drivers.
Main Gaming PC
CPU: Ryzen 9 3900X
Motherboard: AsRock X570 Taichi
RAM: G.Skill TridentZ Neo 3733MHz 2 x 16GB (16-16-16-16-36)
Case: Phanteks Enthoo Pro E-ATX
GPU: MSI GTX 1080 ti Armor OC (2.1GHz/12208MT/s)
HDD: Samsung 970 Evo 250GB NVME SSD, Crucial M500 960GB SATA III SSD, Seagate IronWolf NAS 4TB 7200RPM HDD
PSU: EVGA Supernova 750W Platinum PQ
OS: Windows 10 Pro
Monitor: Sceptre 27” VA 1080p 144hz curved, Acer 21.5” 1080p 75hz IPS
Keyboard: Logitech G213 Prodigy
Mouse: Logitech G502 Hero
Old Gaming PC
CPU: Intel i7-5775C (Broadwell)
Motherboard: ASUS Z97E/USB 3.1
RAM: G.Skill RipjawsX 1600MHz 2 x 4GB DDR3
Case: Fractal Design Focus G
GPU: EVGA GTX 1070 SC
HDD: Kingston A400 120GB SSD, Seagate Barracuda 2TB 7200RPM HDD
PSU: Corsair RM850X Gold (2015)
OS: Ubuntu 18.04.4 (Bionic Beaver) LTS
Monitor: Acer 21.5” 1080p 75hz IPS
Keyboard: Dell USB Slim Keyboard
Mouse: Weird Chinesium Mouse
its a freesync monitor, where do I find the option to enable or disable? And i'm very new to pcs. How do I install a clean chipset and graphic drivers without messing anything up?
Okay for Freesync first you have to have it enabled via the monitor’s own options menu, then you can enable it in the Nvidia control panel, but only if you are connected via DisplayPort, FreeSync over HDMI on an Nvidia card does not work. You also have to be running Windows 10 I believe.
For clean driver installs you’ll want to download DDU, unzip it and run it in safe mode, on windows 10 to get into safe mode just hold shift down as you click restart, for windows 7/8.1 just press f8 just after the motherboard splash screen goes away. Once it completes you then install the new graphics driver, in which case I’d tell it to do a clean install under custom install, just in case DDU missed anything.
DDU: https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Main Gaming PC
CPU: Ryzen 9 3900X
OS: Windows 10 Pro
Old Gaming PC
Ah okay, what will this do after everything?
and yeah, im connected via DP.
Oh and a quick note, is this gpu worth it/good? https://www.amazon.co.uk/Palit-RTX2070-Dual-Graphics-Card/dp/B081DGCP5P/ref=sr_1_3?keywords=rtx+2070&qid=1585428880&sr=8-3
It'll ensure any driver conflicts are out of the question, i.e. a bad driver install or a broken driver. And it'll rule it out to a monitor issue.
It looks pretty good to me, as long as you don't use more than 3 monitors, the cooling is good etc.
Main Gaming PC
CPU: Ryzen 9 3900X
OS: Windows 10 Pro
Old Gaming PC
