How to set max speed for this cpu ?
41 minutes ago, Electronics Wizardy said:If you want to overclock, Id probably just use PBO in ryzen master in windows.
Agreed, manual OC for 3rd gen Ryzen is not recommended anyways.
1 hour ago, Coolday said:I have the cpu 3800x and motherboard Asus tuf + wifi x570. How I can set this cpu speed to 4.5GHz like the specification ?
It should boost to 4.5GHz under load.
Anyways, 3rd gen Ryzen doesn't really OC well, nor does it yield much performance gained, fast RAM and adjusting PBO settings in Ryzen Master is best. 3rd gen Ryzen CPU's seem to show faster degradation symptoms if higher voltages are applied (something I recently learned). For long term 'safe' OC'ing voltages below 1.375V were considered to be fine. However, this rule of thumb is adopted from overclocking Intel CPU's, and previous generations of AMD CPU's. So for long term use I would NOT recommend OC'ing. Keeping the voltage low and adjusting PBO settings is the safest way to squeeze out some extra performance.
https://www.reddit.com/r/overclocking/comments/ejd5c9/1325v_is_not_safe_for_zen_2/
