Dark Rock Pro 4 help
Solved by WoodenMarker,
2 minutes ago, Bigdaddy6969 said:i also like the phanteks p400a but i don't know which cpu cooler i can pair it to
germany ,amazon probably , no budget limit (no need for overkill)
The NH-D15S is a good alternative: https://de.pcpartpicker.com/product/xCL7YJ/noctua-cpu-cooler-nhd15s
That being said, it seems like the DRP4 should fit fine:
https://de.pcpartpicker.com/b/P2HhP6
https://de.pcpartpicker.com/b/YC3bt6
The P400A is a great option if you're interested in better cooling.
Posts merged. FYI, you can use the Edit button to add more info instead of making multiple posts.
