Need help with splitting string and making it into decimal
Johanes
Public Class Form1
    Public listProdAndPrice As New List(Of String)
    Public totalPrice As New Decimal
    Public splitValue As New Decimal
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles btnAddToList.Click
        lsbProdAndPrice.Items.Clear()
        listProdAndPrice.Add(txbProdName.Text & " - P" & txbProdPrice.Text)
        For Each lsbItems In listProdAndPrice
            lsbProdAndPrice.Items.Add(lsbItems)
            splitValue =
        Next
    End Sub
End Class
(Code is not complete)
im just stuck with this problem Q.Q i want to split a string from a list and take the value that i wanted and turn it into a decimal so i can compute it into its total
(Here is what my form looks like)
my main problem is i want to split a string and then turn a string into a decimal.
here is an example of the form when its populated.
You can fuss around with regex, splitting strings, checking input, etc.
Or... You are better off making a new class.
This looks like Visual Basic, which I am not totally familiar with, but with C# I would just simply make a new class called 'Product' with two (or more) properties. The name and price properties, which would be string and int/double respectively.
Then when a user creates a new product, you simply make a new instance of this class, provide the price and product name (of course checking if price is actually a number) and then simply add this to the list (make it a list of Products, not a list of strings anymore). Now you can display the price, the name, etc. but when the user clicks on it to pay, you can simply 'ask' this Product's (class') price.
If you don't want to bother doing that, you should - as mentioned above - do some stuff with splitting strings and such. If you want help with that, please provide some more context on how the whole string will look in action.
well the string would look like this "Apple - P20.00" in the list.. so i want to split this string to "Apple - P" "20.00" and then take the "20.00" and turn it into a decimal so that i can total it...
In that situation I would create a for-loop that starts at the right end of the word and move back. Then I would keep going until it found the P (assuming the P is the currency sign and always appears in front of the money?). That way you know for sure you don't split it on the wrong thing.
Although I would still recommend the specific Product class approach.
yeah i would love to know how to do that class thing as well.. but we haven't discussed that in our school yet..
the code already has a for loop statement in it. its just the taking the string and making it into decimal thats giving me a hard time >.>
I would just update a global variable with the total as you add / remove stuff, then put the item name and price into the text box.
Much more efficient as there would be no need for any loops
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
i would just split the string on the "-" character, then trim spaces on both segments , then take all 0-9 and dot or , characters (some countries may use comma instead of dot) and put them in another string until you encounter an invalid character
ex
"Apple - P20.00" =>  0: "Apple "  1: " P20.00"
trim => 0: "Apple"  1: "P20.00"
backwards until not 0..9 or dot
number = "20.00"
there's conversion functions built in to convert valid string to float, currency etc
But in an ideal world, you should hold the data into an array with 2 properties per entry , ex name="apple"  price = 2000 (store number internally without decimals, just multiply by 100 or whatever) and separate what's in the list on screen by what's in that array.
You can use listIndex property or something like that when user clicks in the list to look up in the array and take from there the name and price.
The reason for this is because you may want to add more stuff in the future and then you'd have to edit the code in several places every time a feature is added.
Also, you may have a very long product name which may be wider than the list width, and then maybe you'd want to truncate it so that you'd see the price on the right side.
Btw... note that you can have list controls with two columns, so you could have the price in a column which has fixed width and the product name in the other column (which may truncate the text automatically if too long)
thanks for all the replies.. i am still rapping my head with this and all this new ideas are helping me greatly.
For sure, splitting strings would be a last resort kind of thing. But it really depends on the complexity and function of the code.
If for example you added another one of the same product, does it go on a separate line? Add one more and double the price? etc. Those are times when you want the price to be separate for example..
But assuming this is some school code, this would probably suffice too.
This seems like a good idea too, to have the price in a separate column. On top of it looking neater, it's also easier to do math with it.
What I find the issue with splitting the string at the dash is that if add an item that costs 10 currency, with the name "Apple - Apple 10" for example, this programs would format that as "Apple - Apple 10 - P10", when split you have to specifically call the last item in that array. Otherwise if you just assume the price is always within the second part, it will screw up.
But that just further points to what I said before in my post. It really depends on how complex this code should be. What I mentioned before is something to keep in mind for a full program, not a 'simple' homework assignment.
Looks like the Val or Double.Parse methods are used in VB for this.
If you have "20.00" separate from the rest as a string, you can use something like this:
double output = Double.Parse(input);
Maybe you can do the loop, but also call sql...use sql functions to do your conversion work ?  I'm guessing you are connected to a sql server ?  I don't know the functions in sql server...
Public Function ConnectToSQL() As String
    Dim con As New SqlConnection
    Dim reader As SqlDataReader
    Try
        con.ConnectionString = "Data Source=(local);Initial Catalog=TestDatabase;Persist Security Info=True;User ID=sa;Password=afm"
        Dim cmd As New SqlCommand("SELECT some_fancy_functions(" || input_string || ") FROM dual", con)
        con.Open()
        Console.WriteLine("Connection Opened")
        ' Execute Query    '
        reader = cmd.ExecuteReader()
        While reader.Read()
            Console.WriteLine(String.Format("{0}, {1}", _
               reader(0), reader(1)))
            'NOTE: (^^) You are trying to read 2 columns here, but you only        '
            '   SELECT-ed one (username) originally...                             '
            ' , Also, you can call the columns by name(string), not just by number '
        End While
    Catch ex As Exception
        MessageBox.Show("Error while connecting to SQL Server." & ex.Message)
    Finally
        con.Close() 'Whether there is error or not. Close the connection.    '
    End Try
    'Return reader { note: reader is not valid after it is closed }          '
    Return "done"
End Function
AAAGHH... switching from Python to VB.net and datatype manipulation is soo weird >.>
