Search In
  • More options...
Find results that contain...
Find results in...
Axel-
Air or water cooling
Recommended Posts
Posted · Original PosterOP
I’m thinking about buying a new graphics card and I wonder if I should get a water cooled or air cooled
What watercooling do you mean?
Open loop or aio?
Also which card do you want to get?
Open loop or aio?
I’m thinking about a MSI GeForce RTX 2080 SUPER SEA HAWK EK X card
So open loop then.
That's a fine card, also a good option if you like to have warranty even with a custom loop.
Keep in mind you need to buy all other components (if you don't have them already): radiator, pump, reservoir,...
I don’t care much for the cards with the blocks on them already as it just makes resale a bit difficult later. But it is a great convince to throw the card in a loop.
But they are rarely offered on a board I’d actually want to pay that price for.
Main RIg Corsair Air 540, I7 8700k, ASUS ROG Strix Z370-H, G.Skill TridentZ 16GB, EVGA 1080TI SC Black, EVGA 850 GQ, Acer xG270HU 2560x1440@144hz
Spare RIg Corsair Air 540, I7 4770K, Asus Maximus VI Extreme, G.Skill Ares 32Gb, EVGA 1080sc & 1060 SSC, Corsair CX850M, Acer KG251Q 1920x1080@240hz
5 hours ago, Axel- said:
So, air is a better cooling solution
What does better mean to you?
