Search In
  • More options...
Find results that contain...
Find results in...
GILDEF
I need help with choosing a CPU
Recommended Posts
Posted · Original PosterOP
I want to upgrade my i3 7100 (2 cores misery)
Motherboard: MSI pro-vdh
GPU: 1050ti
RAM: 16gb
The budget is around 300$ - 350$
I want a 4 cores budget processor and a motherboard for it. It can be Intel or AMD.
Please help.
Country?
Ryzen 5 3600 and msi b450 tomahawk max with your old ram.
|Ryzen 7 3700x || Asus strix 5700 XT || Asus strix x570-E || G.skill tridentZ Neo 32gb 3666mhz cl16-19-19-19-39 || cooler master ml360 RGB AIO || Kolink Horizon RGB || Thermaltake grand rgb 750w 80+gold psu || samsun 250 gig ssd || toshiba 5400rpm 1tb hdd || HyperX cloud alpha || Corsair k55 || Asus gladius 2 origin gaming mouse || Asus 1080p 144hz || monitor 2nd monitor aoc 1080p 75hz ||   GUOTE ME, FOR ME TO BE ABLE TO SEE YOUR COMMENT🥰
https://pcpartpicker.com/list/NJ6kzN
3 minutes ago, SavageNeo said:
Country?
Bulgaria. It's kinda expensive here. Don't want to sell my kidney lol.
Well, if you dont want to change your motherboard, you should go with a Ryzen 5 2600/2600x or a Ryzen 7 2700/2700X. Depends on what your ram is (DDR4-2133, DDR-2666?)
If its budget u want then an AMD 3200G APU using your ram and Video Card.
Motherboard i would opt for anything MSI.
MAIN PC (Beast) - Asus ROG Crosshair Hero VII WIFI , AMD Ryzen 7 2700x + Corsair H115i Pro RGB Cooling, 32GB G.Skill 3200Mhz 16,18,18,38 1.35v DDR4, Inno3d HerculeZ Design Nvidia GTX 1080 X2 8GB GDDR5,  2 x Samsung U28E590D 3840 x 2160 4K, 1 x Samsung Evo 970 NVME PCI-E 500GB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 3TB Seagate Baracuda SATA III, 1 x LG BH16NS40 16x BR\DVDRW, Corsair Obsidian 750D Windforce Edition Case + 5 Corsair ML140 140mm Case Fans, EVGA 750 g3 750w Gold 80+ PSU, Logitech MX Vertical Mouse, Corsair K55 RGB Gaming Keyboard, Windows 10 Pro x64 Retail, Synology ds215j NAS + 2x3TB WD Reds connected to a 6TB Seagate USB 3.0 Backup Plus Hub, Logitech C920 Webcam, Blue Yeti Microphone, ESET Internet Security 2019 V12..
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Venegence Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Baracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Kaspersky Internet Security 2019, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Kaspersky Internet Security 2019.
Printers Include - Canon MG5750, Canon, IP8750, 2 X Samsung C410W.
Asus AC-RT86 Cable Router Using a Virgin Media Hub 3.0.
Internet Speed.....
https://www.speedtest.net/result/8311508380
He'd still need to change his motherboard because he is on Intel.
Best option is what SavageNeo said, because you have an external gpu don't bother with an APU.
He will have to change his board to get an AMD Chip as his current board is INTEL.
Internet Speed.....
Best option is what SavageNeo said.
Mate, the MSI PRO-VHD (the motherboard in his original post) supports am4 (1&2 gen)
4 minutes ago, GILDEF said:
Bulgaria
altech.bg website: image.thumb.png.5ba77179532251c13abb959e5f8111d5.png
No, you are looking at the wrong board. For starters, there are tons of MSI PRO-VHD, for different chipsets, spanning Intel and AMD.
OP stated he has an Intel i3-7100
OP: your cheapest route may be to buy a used i5-7xxx, maybe a used i7-7xxx
I'm retarded. It's b250m pro-vdh.
Intel and AMD make socket/chipset in commons now ? Pro-VHD exist for b250/b360 (intel) and b350/b450 (AMD).
Don't forget to quote (arrow bottom left of the message) or use name tag (@name) for us to see your answer.
Well, then go with SavageNeo
Its fine. The ryzen 5 3600 is so much better than your i3 than you can imagine. But still, you could go cheaper.
I'm kinda broke ngl.
What about Ryzen 3 2300x or Ryzen 5 1600?
Ryzen 5 1600 looks nice with it's six cores and reasonable price.
ok, i just found a decent motherboard with a good processor, maybe thats something for you...
The motherboard has only 2 memory slots.
I think Ryzen 5 1600 is the max that I can afford.
Well, you said your budget is 300-350 euros. Tell me a new budget and what you need the processor for (gaming, editing, etc.)?
and the mainboard has 4 slots
$ pretty sure that's a dollar sign
doesnt matter, whats you real budget
270$.
How about Ryzen 5 1600 and MSI b450m-a pro max?
270$.
i'd still recommend the ryzen 5 2600, because its not that "old" and its only 20$ more, but you can go with the ryzen 5 1600 or the ryzen 5 2600, as you like
You should go with a 2600 and a cheap b450 board, seeing as the 3600 still does not justify the price gap and the 1600 and 2600 are similar in price and are worth that little extra.
