Need help with Computer Monitor Audio
Antiguy19942
I have the LG Ultragear Monitor that sadly doesn't have built in speakers. The only possible way of getting audio from it is a headphone jack in the back. I was wondering if its possible to hook them up to some external speakers? My dad has small speakers that connect with speaker wire can I convert it to pull the audio from the headphone jack by converting the signals like speaker wire to rca and flip the rca to the headphone jack? Do I need a special converter box or wire? If you got suggestion I will greatly appreciate it.
https://www.costco.com/lg-ultragear-27"-class-fhd-ips-g-sync-compatible-gaming-monitor.product.100512138.html
Thanks I figured that I would need something like that I just couldn't find it.
