Does over ear headphones good than on ear headphone in sound quality?
220VoltsallCore
1 minute ago, Dinesh1 said:
And  which is more  comfortable?
How comfortable they are depends on the headphones and your personal taste. Some people find over-ears more comfortable, others find in-ears more comfortable. Also, which ones produce better-quality sound depends...on the headphones in question.
I have on-ear headphone and while the sound is pretty good, the comfort is terrible. All my other over-ear headphones have great comfort and some have amazing comfort.
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
That depends on you and the headphones. You can have really light clamp headphones like the kph30i and it will be fine . But most of the good stuff is over ear anyway
