HELP: Yamaha MG10XU Recording Issue
ForTheWinTCG
Hi.
So my current setup for my mixer is very simple. I have my mic [Shure SM7B] going into 'Line 1' and my speaker connected to the R/L ports of 'Stereo Out'. The mixer itself is connected to my PC through USB. My issue here is that when I record [either with OBS or Audacity] both the Mic & PC audio are going into the same track rather than 2 independent tracks. As someone who records music this means I cannot record vocals on its own as the music in the background also get's recorded. This wasn't an issue for me before but somehow this has occurred and I have no idea how to separate the mic audio from the PC audio. I have attached photos of the Mixer setup & OBS to show what I mean. If anyone could help that would honestly be amazing. Thanks.
Before:
Now:
Before I even do any further troubleshooting... have you tried updating? You're using an archaic version of OBS according to your screenshots.
But, your mixer setup has always been the same?
The MG10XU's USB input records whatever is being sent to the main stereo mix.
Since you're sending the USB output to the stereo mix it's being looped back into the recording, you have to send the USB output to 'MON' (Monitor / Phones) to avoid this:
It's set up this way because it's not typically practical to use speakers and a mic at the same time as the mic will pick up the speakers anyway. I also notice you've got an adapter on one of the speaker outputs:
Probably just whatever you had on hand to make that work, but just want to make sure you don't have your headphones plugged into that or something.
Main PC: Corsair 900D | ProArt Z690-Creator | Intel 13900K | RTX 4090 | Trident Z5 (2x32GB) | 1TB 980 Pro, 2TB Sabrent Rocket 4+, 2TB 980 Pro, 1TB Sabrent Rocket | HX1200i
Capture PC: Meshify XL | Designare TRX40 | AMD 3960X | 2xRTX 4070 TI | Trident Z (4x16GB) | 2TB 970 Evo Plus, 1TB 970 Evo Plus | Dual HDMI 4K Plus LT, 2xElgato 4K 60 Pro, HX850
Media / Render PC: Corsair 900D (shared) | ASRock X399M | AMD 2970WX | RTX 4070 TI | Trident Z (2x16GB) | 2TB Samsung 970 Evo | 2xElgato HD60 Pro | HX750
Full Room Watercooling: EK X3 400 | EK-XTOP Revo Dual D5 | 4xHardware Labs 560GTX | 16xSilentWings 4 Pro  | EVGA 450 B3
Peripherals: Logitech G502 X |  Wooting 60HE | Xbox Elite Controller Series 2 | Logitech G502 Wireless | Logitech MX Keys Mechanical
Displays: Asus XG35VQ | 2xLG 24UD58-B | LG 65UH6030 | Asus VH242H | BenQ GW2480 | HP 22CWA | Kenowa CNC-1080P | Asus VC39H
Audio Interfaces : RME Fireface UFX+, Scarlett 18i20, RME HDSPe RayDAT, RME HDSPe MADI FX, RME ADI-648, RME ADI-192 DD
Audio Playback: 2xYamaha HS5 & Yamaha HS8s | Sennheiser HD820, Sennheiser IE 500 Pro, Ultimate Ears RR CIEMs
