Power outage, psu and pc components.
Rumman
Which component is the major affected one in terms of power outage?
Does a good psu can minimize the Affect of power outage on the components?
Thanks
a little big, but you should probably just look into a UPS, which just fixes that issue to quite some extent.
Thanks
If you're using a quality PSU, there should be no impact to your hardware.
But nobody likes their PC shutting down on them in the middle of things.  It's also not good for keeping your data free from corruption.  So if you have a lot of power outages, you want to get a UPS.
