Search In
  • More options...
Find results that contain...
Find results in...
Mr Acrimony
Inverted atx motherboard into atx case
Recommended Posts
Posted · Original PosterOP
So i've had this question for a long time and don't really know where to ask it so my apologies if this is not the right place.
And Like the title says, is this possible ?
Thanks in advance.
It could work, but how are you going to access the rear I/O since they are now pointing inwards?
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
