Search In
  • More options...
Find results that contain...
Find results in...
Crazy_kiko
Difference between G.SKILL Trident Z Neo/G.SKILL Trident Z
Recommended Posts
Posted · Original PosterOP
I build a pc with an AMD 3800x + asus rog strix x570-f gaming + dual channel kit  2x8gb G.SKILL Trident Z  CL 16-19-19-39 ( non NEO ),  i update the BIOS but i have to putt manually the memory frequency in 3600MHZ because it only shows 2133 ( it's normal or maybe it's  because it's not de NEO version ) another problem i have is the Trident Z Lighting Control  ( light control of the rams is not working at all ) it's normal ? Someone had the same problem?
thanks for all help given ;)
money, the small differences latency could add up when comparing the worst to the best, but gskill is already pretty high end. So just get whichever and never notice the difference.
All ram require you to increase the speed from 2133, the motherboard doesn't do it automatically.
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 960 EVO Series - 1TB PCIe NVMe - M.2 Internal PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: GeForce RTX 2080 GAMING X TRIO RAM: Corsair Dominator Platinum 32GB (2 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
Mostly marketing as Ryzen IMCs have come a loooooooong way from needing something specifically crafted for Ryzen, but it does show up on a lot of QVL which means boards will have better pre-set timings and dies usually have a lot more testing. Not memory expert though. Perhaps one will come along. I'd link the page where they explain it, but it's mostly marketing fluff.
Build Logs: Cotton Candy Threads | Lucid Visions | Matte Machine (4U Rackmount) | Noc Noc | NUC | Storage Log
Cotton Candy Threads - CPU AMD Threadripper 2950X | GPU EVGA FTW3 RTX 2080 Ti | MOBO Asus ROG Zenith Extreme | MEMORY 128GB (8x 16GB) Corsair Vengeance RGB 3200 | STORAGE 3x Samsung 960 Evo SSD + 4x Crucial P1 1TB + 2x Seagate Ironwolf 8TB 7.2k HDDs | PSU Corsair HX1200i w/ Cablemod Pro Extensions | COOLING Cooler Master TR4 ML360 | CASE Lian Li O11 Dynamic Black | LIGHTING 9x Corsair HD120 Fans, 4x Corsair Addressable RGB Strips, 2x Corsair Commander Pro | PCPP
LUCID VISIONS - CPU AMD Ryzen 9 3950X | GPU PowerColor 5700XT Liquid Devil | MOBO Crosshair VII Hero | MEMORY 64GB (4x 16GB) Trident-Z Neo @ 3733 | STORAGE Samsung 960 Pro SSD | PSU Corsair RM1000i | COOLING EKWB Custom Loop | CASE Define S2 Vision | LIGHTING 4x Fractal Prisma AL-14 Fans, Built-in RGB Strip | PCPP
Just NCASE mITX - CPU Intel Core i7 8700K @ 5.2GHz | GPU EVGA RTX 2080 Ti XC | MOBO Asus Z370-I Gaming | MEMORY 16GB (2x 8GB) G.Skill Triden-Z RGB 3000 | STORAGE Samsung 960 Evo 500GB SSD + Corsair MX500 1TB M.2 SSD | PSU Corsair SF600 | COOLING Noctua NH-U9S w/ Redux Push/Pull Fans | CASE NCase M1v5 | LIGHTING 2x Cablemod Addressable RGB Strips | PCPP
Noc Noc, Who's There? - CPU AMD Threadripper 1950X | GPU ASUS RTX 2080 Ti OC | MOBO ASRock X399M Taichi | MEMORY 32GB (4x 8GB) GSkill Trident-Z 3200 | STORAGE Samsung 970 Evo SSD | PSU Corsair HX1000i w/ Cablemod Pro B&W Kit | COOLING Noctua U9 TR4 w/ 2x Redux 92mm | CASE Corsair 280X White | FANS 6x Noctua 140mm Redux | PCPP
