fiber optic ethernet cable to run from pc to modem/router
Solved by Windows7ge,
Cat5e copper Ethernet cables can run 100m(328ft.) at 1Gbit before seeing any performance or reliability degradation.
But if you are insistent in your idea you could use media converters. Connect copper to the media converter. Run fiber to your room. Convert back to copper. I don't really recommend it though unless you have a seriously far away computer. Beyond 100m away.
