Search In
  • More options...
Find results that contain...
Find results in...
Not Wills
Will a fan header power these OEM lights
Recommended Posts
The voltage should be written on the LED strip itself, I can't see anything from these blurry pictures, though since it's using a Fan Header then it *should* be 12V but OEMs break standards sometimes so I can't be sure.
Quote or Tag people so they know that you've replied, otherwise you'd just be talking to yourself.
Posted (edited) · Original PosterOP
Screenshot_20200114-210739.thumb.png.321e059aceccb935ab236f081b8bbfff.pngread above as well
Edited by Not Wills
Posted · Original PosterOP
4 minutes ago, lafrente said:
I don't think you should put RGB into fan header. It should go into RGB header on the motherboard.
Il try that as I put it in the OEM machine and it works
1 hour ago, Not Wills said:
Also the case smells like a burning elecronics
That’s not very good sign tbh, I would try to double check everything, all cables etc, make sure none of them are melting
   @Whiro tag or quote will do the trick
i5 3570K @ 4.5Ghz  |  CM Hyper 212 Black  |  AsRock Fatal1ty Z77 Performance  |  Corsair Vengeance 16GB (4x4) 1600MHz  |  ASUS Strix GTX 970 OC  |  Phanteks P400S TG  |  EVGA 500W1  |  Storage: Corsair 60GB SSD (boot), Gigabyte 120GB SSD, WD 2Tb HDD
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
2 hours ago, Not Wills said:
It does not have a indicated of voltage
nott sure what the small black wire that jumpers two connections together is for (fan headers usually dont need that to supply power to the port (it could be shorting to the PWM pin on the fan header-not needed for that light)
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it 🙂
https://www.latlmes.com/breaking/minecraft-shutting-down-in-2021-1
