Radeon 2020 stupid zero fan speed done broke my fancurve
Ozz
So, as the title states, just got the radeon 2020 thing and updated drivers (for my PowerColor RX 5700 non XT, non red dragon) installed, and my MSI-AB fan curve is broken, and now the fan wont turn on at all untill the card hits 60c, and its now idling at 55-60c. What did AMD break and how do I fix it so I have control over my fan curve again?
What are load temps like?
Modern GPU's fans won't spin until they hit a certain temperature.
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
Load temps are normal, ~70 when running a game with some high settings, and ~55c for lesser easier to run games. I also set my fan curve to always be spinning to keep my GPU at ~35c at idle. i dont like idling at 50-60. my issue is i have no control over my fans. my MSI fan curve is not being used, neither is any curve i set in the radeon software itself. control over my fans has been stolen from me.
Try reinstall msi afterburner , it may overwrite the settings.
   @Whiro tag or quote will do the trick
i5 3570K @ 4.7Ghz  |  AsRock Fatal1ty Z77 Performance  |  Corsair Vengeance 16GB 1600MHz  |  ASUS Strix GTX 970 OC  |  Phanteks P400S TG  (mesh panel) |  EVGA 500W1  |  Storage: Corsair 60GB SSD (boot), Gigabyte 120GB SSD, WD 2Tb HDD | Cooling: Custom loop
                EKWB EK-XRES 140 Revo D5 RGB PWM
                EKWB EK Supremacy Evo , naked die
                EKWB EK Thermosphere
                EKWB EK CoolStream PE 360
                EKWB EK Coolstream SE 120
                EKWB EK Vardar 120s  x6
                EKWB EK STC Classic 10/16  x10
                EKWB EK DuraClear Tubing 16/10
                EKWB EK CryoFuel Acid Green
Laptop: Gigabyte G5-KC | i5 10500H | RTX 3060
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
