Fan makes wierd noise every 5 seconds
Ithinker23
How about replacing it?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
6 minutes ago, Ithinker23 said:
For some reason my fan makes a wierd noise every 5 seconds i have a video of
Sounds like it's scraping against something or the bearing in the fan is starting to go bad if it's reoccurring. You can try taking it apart and lubricating it which can help sometimes but if can get a replacement then it would be a good option.
I opened the bottom of the computer and found this
Yeah that's pretty conclusive, if you can find a part number or spec label you're probably best to just get a complete replacement fan.
