h710 case mod for better flow
Squeeeeeeeps
I recently made some fairly easy mods on the NZXT H710 I just built to improve the airflow. It might be a little funky but so far it's getting the job done. Hopefully this helps someone as this case seems like it would be pretty hard to get adequate air on some higher end builds.
For reference the GPU Temps are at 95% usage and under similar conditions (cooler is Kraken X62, internal fans are stock x4):
Before:  76C with the front panel on (pump + radiator fans 90-100%)
               71C with the front panel off (pump + rad fans 70-90%)
After:   ~66C-71C with the front panel on or off (pump 70% + rad fans 50%)
Before I had 4 exhaust fans (1 back, 3 top) and my 2x radiator fans were the only intakes on the front. Now this I really didn't like anything about it. The fans were noisy, it wasn't positive pressure, and I felt like the temps were really bad if the only way to get near 70C was to take the front panel off to let more air in... especially because the reason i bought the case was for the aesthetic.
My plan was to flip one of the fans up top around and turn it into an intake. The problem here is that the 3 top fans all share the same chamber and there is a panel sitting directly in front of the fans, the only ventilation is on the sides. Air is pushed in and out with brute force. I wanted to segregate the new intake fan up top from the 2 exhaust fans. I didn't want them stealing air from each other and having the intake recirculating hot air.
The best quick solution I could come up with was to take some dense packing foam that came with the case and cut it up to make a divider. I kept it snug so I could try to keep the best suction as possible on the intake fan.
Looking at the radiator fans I noticed they were very prone to recirculation and losing suction as well. I cut a small piece of cardboard from the back of a notebook to close the fans off from the inside of the PC. Other than that I used a little bit of electrical tape here and there to fine tune the leaks from the intake chambers leading back into the internals.
That's it! It's not the prettiest or most perfect way to seal it off, but it worked pretty damn well and you can't even see what I did when the covers are back on! It's a whole lot quieter too. I haven't fine tuned the case fans in the BIOS yet, but it feels like I've achieved positive pressure and I'm pretty happy with it so far. Now if I ever decide to overclock it, I might end up upgrading the fans to deal with the extra heat, we'll see.
This is my first PC build and I'm new to this world so take it easy on me lol. Just posting this in hopes it can help someone out as this case's stock airflow is kinda trash.
I like it, seems like my kind of mod. Decrease fan speed but lowering temps is a successful mod, it's also fun to experiment.
I used to spend time trying stuff like this back with my skylake i7-6700k system. I was always trying to improve airflow, I ended up turning my Thermaltake suppressor F31 into basically what I have now, the Fractal Design Meshify, by creating a mesh front panel mod and fitting 3x 140mm fans up front for intake, was a drastic improvement.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
Wow, that's a nice mod, was it a lot of work making the mesh panel?
I'll try the radiator up top and compare both my CPU and GPU temps now.
15 hours ago, Caroline said:
Ah, the magic of NZXT... does less costs more, and you always have to end up modding
Haha yeah I'm figuring that out. I don't mind tinkering, it helps me learn, but next build I'll go with something like a meshify
On 12/9/2019 at 5:58 PM, Squeeeeeeeps said:
Did you try moving the radiator to the top as an exhaust and use 3 of the 120mm fans as an intake on the front? The radiator is dumping warm/hot air inside the case from the front, that's why the gpu was hot.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
I was just thinking about doing that today. It's pretty obvious now that I think about it, but I didn't realize the intake was pushing air through the hot radiator when I first went with that setup.
I'm going to keep it a day or two to see how my CPU temperature currently is with the tasks I run. Then I'll make the switch, and compare the two. I'm expecting it'll drop a couple more Celsius and I'll more than likely keep the radiator up top
Edited by Squeeeeeeeps
Yeah took a while to figure out the proper execution and getting the proper materials, but end result was worth it.
My Builds:
MEGA Desk Build
what mesh panel? i dont see any mesh panel in the pictures.
Mine's not mesh, it's solid. JM21 was talking about a mod he had previously done
Got an update: I moved back to a top exhaust w/ 3 120mm intakes in the front... the GPU temp is about 69C so no change there, but the CPU temp seems to have risen about 10C all under similar conditions with the same fan curves. Also the fan noise seems louder.
So it seems a bit odd, But my previous setup seemed better for me and this case. I had the radiator intake in the front, with 1 intake fan up top right above the radiator, then the 2 top/back fans being exhaust and the rear fan exhaust. About the same GPU temp here, but much quieter with lower CPU temp.
I was hoping to reach low 60's and eventually start OC'ing, so I wish i could think of a better config to improve temperatures. I could spend more money on better fans, but I'm really not interested in that right now.
