Are those parts good for a 1000€ budget pc?
13 minutes ago, lilotus.FRM said:
And I definitly fell in love with the CM H500 case :)
It's literally a(n RGB) wind tunnel for your components to sit in. It's dope.
I was thinking about maybe buying another 200mm fan and putting it at the top but I‘ll wait for stuff like that.
See how good she blows first. You can always ask for a better blow later. ;)
Yea ;)
But fr I could also use that space at the top for an aio watercooling someday.
18 minutes ago, lilotus.FRM said:
Yea ;)
It's likely that 3x 200mm intakes would be way too much for the little 120mm exhaust :P
But that top slot is where I would put a radiator for an AIO, yeah :)
I'd get a really solid air cooler though. A higher end cooler would just make the wind tunnel all the more tunneled.
34 minutes ago, lilotus.FRM said:
I looked up the prices in germany.
Here is a screenshot of it for you.964386D9-F6B3-4F50-818D-D67BE4D14744.thumb.jpeg.bfcf5027d8841787aff54c228a39b478.jpeg
The Pulse indicates a slightly better cooling estimate there. (For the same price as the Gigabyte)
The boost clock is 1925mhz vs 1905. (Not a huge disparity, but that number is determined by thermal data, indicating a better thermal performance out of the Pulse, meaning better cooling for an overclock.
The Pulse actually costs 10€ more cause of the shipping.
EDIT: The gaming oc has the same shipping price.
Does it make a lot of difference when I‘m gaming if I am using the Pulse or the Gaming OC?
Not at all. They are very comparable.
Okay because I think the Gaming OC is more good looking and I gotta keep my nickname as the „aesthetic god“ yk.
Hahahaha yeah, nah whichever is fine. Both will perform about the same and should overclock a bit for you when you want to get into that.
Okay thanks! I really appreciate your help.
EDIT: Do you know if the backplate from the Gaming OC is metal?
I really want to have a modular power supply. Wich one can you recommend?
BitFenix Whisper or RMx are my general suggestions.
Thank you!
