Motherboard, Case, and CPU fan Compability
Wehr_Wolff
My main question is if the https://de.pcpartpicker.com/product/XJbCmG/msi-b450-a-pro-max-atx-am4-motherboard-b450-a-pro-max
is compatible with these fans and how much the Fan would block certain things. Like Ram Clearance and so on. Or how I could mount the fan to not block certain things
This is the case https://de.pcpartpicker.com/product/qvF48d/be-quiet-silent-base-801-window-silver-atx-mid-tower-case-bgw30
and the above mentioned motherboard and this Fan. (CPU is a Ryzen 7 3700x)
https://noctua.at/en/nh-d15-se-am4
This case https://de.pcpartpicker.com/product/QdXYcf/phanteks-eclipse-p400a-digital-atx-mid-tower-case-ph-ec400atg_dbk
with the above mentioned motherboard and these fans. (CPU is a Ryzen 5 3600)
https://de.pcpartpicker.com/product/FRYLrH/be-quiet-dark-rock-4-cpu-cooler-bk021
https://de.pcpartpicker.com/product/krxbt6/be-quiet-dark-rock-slim-cpu-cooler-bk024
Ram for both would be https://de.pcpartpicker.com/product/ckvbt6 diffrent Frequenzy versions of this kit. First one with 3600 Mhz and second with 3200 Mhz
thx a lot
9 minutes ago, Wehr_Wolff said:
Hello,
You can usually place the 1st fan higher to allow better ram compatiblity but then you need a bigger case, you can also move the 1st fan place it in the "3rd" slot or complety remove it.
Also they usually are compatible with low profile ram.
If you buy vengeance or similar low profile ram, you will have no issues with any of the heatsinks and fan placement.
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
Which ram would you recommend then? Because I could just buy new ram and give the one I get to a friend. What would be your recommendation. Because i only find 16 gb ddr3 low profile ram?
The Corsair as mentioned above.
https://de.pcpartpicker.com/product/wZ22FT/corsair-vengeance-lpx-16gb-2-x-8gb-ddr4-3000-memory-cmk16gx4m2d3000c16
Or Crucial Ballistix Sport LT is also low profile. It comes in White as well.
https://de.pcpartpicker.com/product/3BCD4D/crucial-ballistix-sport-lt-16-gb-2-x-8-gb-ddr4-3000-memory-bls2k8g4d30aesbk
Other option would be to get a cooler that doesn't block the ram slots like the ones below.
https://de.pcpartpicker.com/product/PnPKHx/arctic-freezer-34-esports-duo-cpu-cooler-acfre00061a
https://de.pcpartpicker.com/product/gkyV3C/alpenfohn-brocken-3-606-cfm-cpu-cooler-84000000140
