Air flow/ fan set up help
Bklynman671
So I'm using a phanteks p350x case. Can only have a front mounted radiator so I'm using an aio and  I also want the rgb fans to be seen so I'm using it in a "push" config. The fans will push air through the rad out the front of the case( Fan...Rad...Case). My question is should the rear be an exhaust and the top 2 fans be intake? Or is there a better way ?
No, the top fans should be exhaust, and the rear fan should be exhaust as well. If the fans on your radiator are exhausting out of the front and they're between the case and the radiator, that's actually pull (the fans are puling air through the radiator into your case). If you are using a push orientation against the radiator be sure to pull the radiator out and clean it at least once every 3-6 months as dust will build up between the fans and the radiator. The front fans should be pulling fresh air into your case. You'll still see the RGB lights on the fans just fine with this configuration.
Well nothing is really stopping you from doing what you're thinking but you'll be fighting natural convection with top and rear as intake and front as exhaust. You also won't have any dust filtering on that rear fan. I understand the situation you're in as you don't want to be looking at the back of the fan when the rad is mounted in the front (wish they made reverse flow fans for this purpose).
More links in my profile! Builds: Project(Main Rig): Cosmos Sv2 -- 2nd PC: Old School AMD -- Project: HD4890 Revival,
↓↓↓↓↓↓↓↓ Specs Below ↓↓↓↓↓↓↓↓
Cosmos Sv2:
  • CPU: Intel Core i9 9900K @ 5.1ghz
  • Motherboard: Asus PRIME Z390-A
  • RAM: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3000
  • GPU: Asus GeForce RTX 2080 Ti 11 GB Turbo
  • Case: Modded Cosmos S (Cosmos Sv2)
  • Storage: Samsung 970 Evo 500 GB M.2-2280 NVME, WD Black SN750 2TB NVMe, 2x WD Red 2TB raid 1, 150GB Toshiba 2.5"
  • PSU: Corsair HX850
  • Display(s): Samsung LC32JG50QQNZA 32.0" 2560x1440 144 Hz, LG 29UM58-P 29.0" 2560x1080 75 Hz
  • Cooling: Custom Loop
  • Keyboard: Corsair K95 Platinum
  • Mouse: Corsair Dark Core
  • Sound: Oboard with Logitech something or other 5.1 speakers and HyperX Headset
  • OS: Win 10 Pro
  • PC Part Picker URL: https://ca.pcpartpicker.com/user/NotSoEpicMods/saved/LYysZL
Old School AMD:
  • CPU: AMD Phenom II x6 1090T
  • Motherboard: Asus Sabertooth 990FX rev1.0
  • RAM: 16GB Patriot Sector 5
  • GPU: XFX HD 7950
  • Case: Cougar MX330-G Glass Window
  • Storage: 2x HyperX 3K 120GB SSD
  • PSU: Corsair 650W
  • Display(s): Samsung 32"
  • Cooling: Hyper 212+
  • Keyboard: Logitech G110
  • Mouse: Logitech M100
  • Sound: HyperX Headset
  • OS: Win 7 Ultimate
