Thermaltake Pure 12 ARGB fan cable
Tech Reprise
I have seen that the Thermaltake Pure 12 ARGB fan cable sleeving is pretty hard, as a result it doesn't bend like normal braided sleeving rather it kinks in places. Will this cause any damage to the wires inside?
Anyone else with Thermaltake have this same issue? Also their length is abnormally long, like seriously 2ft of cable length -_-
  • AMD Ryzen 7 5700X Stock
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ RGB 3600Mhz 32gb (8gb x4)
  • MSI Mech 2X RX6600
  • Deepcool AK620 WH
  • Deepcool CK500 WH
  • Kingston A2000 250gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
Heavy cable kinking doesn't sound right. But even if it does, the longer length allows running cable in a way that prevents any issues anyway. Kinking can cause damage if it's left like that for long periods. But if you see it happen and fix it, it's fine.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I have checked and its actually the outer sleeve thats kinking, the cable is okay.
  • Deepcool AK620 WH
  • Deepcool CK500 WH
