Do I need a sound card for ASUS ROG Delta USB C headset?
Rolling2405
Do I need a sound card to take full advantage of this headset or is onboard audio good enough? If I am going to get a sound card I am thinking of getting the EVGA NU Audio sound card
Edited by Thomas001
  • My system specs
  • View 91 Tempered Glass RGB Edition, No PSU, XL-ATX, Black, Full Tower Case
  • ROG MAXIMUS XI EXTREME, Intel Z390 Chipset, LGA 1151, HDMI, E-ATX Motherboard
  • Core™ i9-9900K 8-Core 3.6 - 5.0GHz Turbo, LGA 1151, 95W TDP, Processor
  • GeForce RTX™ 2080 Ti OC ROG-STRIX-RTX2080TI-O11G-GAMING, 1350 - 1665MHz, 11GB GDDR6, Graphics Card
  • ROG RYUJIN 360, 360mm Radiator, Liquid Cooling System
  • 32GB Kit (2 x 16GB) Trident Z DDR4 3200MHz, CL14, Silver-Red DIMM Memory
  • AX1600i Digital, 80 PLUS Titanium 1600W, Fanless Mode, Fully Modular, ATX Power Supply
  • Formula 7, 4g, 8.3 (W/m-K), Nano Diamond, Thermal Compound
  • On AIO cooler 6 x NF-F12 IPPC 3000 PWM 120x120x25mm 4Pin Fibre-glass SSO2 Heptaperf Retail
  • 6 x NF-A14 IPPC-3000 PWM 140mm, 3000 RPM, 158.5 CFM, 41.3 dBA, Cooling Fan
  • 1TB 970 PRO 2280, 3500 / 2700 MB/s, V-NAND 2-bit MLC, PCIe 3.0 x4 NVMe, M.2 SSD
  • Windows 10 Pro 64-bit
  • Beyerdynamic MMX 300 (2nd Generation) Premium Gaming Headset
  • ROG PG279Q
  • Corsair K95 Platinum XT
  • ROG Sica
this is a usb headset...you dont need a sound card
besides onboard audio is fine now a days
10 minutes ago, KarathKasun said:
Any USB audio device has its own sound processing hardware built in.  You can use a USB headset on a PC with no audio device installed and it will work fine.
Is there any advantage to getting the analog version of the headset and using a sound card like the EVGA NU Audio sound card?
  • My system specs
  • ROG PG279Q
  • ROG Sica
No the headset isn't really that good and doesn't warrant any other hardware your better off getting the usb c. But if you want something good. Look into other options in the non gaming space such as beyerdynamic, Sennheiser and many others.
So, non gaming headsets are better than gaming ones in terms of comfort and audio quality?
  • My system specs
  • ROG PG279Q
  • ROG Sica
yes
2 minutes ago, rice guru said:
yes
If I get a non gaming one they all seem to be analog headsets so, should I upgrade to a sound card?
  • My system specs
  • ROG PG279Q
  • ROG Sica
depends on what headphone you decide on
Do you have any that you recommend for comfort and audio quality?
  • My system specs
  • ROG PG279Q
  • ROG Sica
what's your total budget?
$350
  • My system specs
  • ROG PG279Q
  • ROG Sica
Just now, Thomas001 said:
$350
what games and music do you listen to and do you mind using a mic on an arm rather than putting it up to your face?
I mostly play open world games like Watch Dogs 2 and Ghost Recon Wildlands. And I play simulator games like X Plane 11, PC Building Simulator, Cooking Simulator and Tech Support Error Unknown. I am planning on getting Watch Dogs Legion and maybe Ghost Recon Breakpoint this Christmas and Microsoft Flight Simulator when it comes out next year. I listen to music on Itunes because I have an Apple Music subscription.
  • My system specs
  • ROG PG279Q
  • ROG Sica
what type of music?
to start we can start looking at the he 4xx, hd 58x , dt 770, 880, and the MMX 300.
how noisey is your environment? if it's quite how do you feel about open back headphones?
1 hour ago, rice guru said:
what type of music?
I mostly listen to pop, easy listening, 80s and 90s music. What’s the difference between open and closed back headphones? My environment is not very noisy.
  • My system specs
  • ROG PG279Q
  • ROG Sica
an open back will let sound out and in to your headphones resulting in a more natural sound and more often than not a wider soundstage which is beneficial for gaming.
from your music tastes I would point you towards a sennheiser HD 58x, akg k371, and the dt 880
Can you recommend some closed back headphones because while my environment is not that noisy I do not want my family to have to listen to whatever I am listening to so, I need headphones that will not let the audio leak out.
  • My system specs
  • ROG PG279Q
  • ROG Sica
Akg k371, DT 770, beyerdynamic custom one studio, ONE MORE triple driver over ear but given your music taste I would reccomend the akg k371
Is there any better ones in terms of comfort and  sound quality? I’m only asking because the AKG K371 are $150 and I’m willing to spend more money if there is something better. What is important to me is comfort and sound quality. What is the absolute best closed back headphones for comfort and audio quality based on the games I play and the music I listen to?
Edited by Thomas001
  • My system specs
  • ROG PG279Q
  • ROG Sica
Well it's all preference. These are a semi closed back but argon mk3 I would say are one of the best but requires a it of power to run a fiio k5 pro should be able to power it.
Also Sony mdr1A. Pretty decent too. There is no such thing as absolute best. Everyone hears things differently. And what people think is best depends on them.
I remember t50rp's being surprisingly power hungry
Crimson Panda
http://pcpartpicker.com/list/g6T8QV
AKG K712 PRO
OL DAC
Magni 3
Not that power hungry when I was testing it required less power than my 250 ohm 990 to run loud . He said he wanted the best so I gave him imo one of the best closed backs under $300. I will say not much can run it properly but a lot of things can run it loud
8 hours ago, rice guru said:
Akg k371
I am think of getting this headphone. Should I get a sound card?
Edited by Thomas001
  • My system specs
  • ROG PG279Q
  • ROG Sica
