Need help with choosing phone.
17 hours ago, Amforev said:Hello
Reacently i have decided that i want to swap my current phone (Nokia 515). I do not want a phone with Android, I have used it in the past and i do not like it. Also i would not like to buy apple products, becouse of their price.
While serching the web i have found another alternatives which were BlackBerry Z10 and Leap. I would like to know if BlackBerry is a safe os (spectre meltodwn, security updates etc.) and which one should i choose.
I will probably be using it to: browse the web, use messeging apps, create notes and listen to music.
Thanks for all answers
Do not get a BlackBerry OS phone. I'm not saying that lightly or as a matter of opinion. BlackBerry is shutting down its app store at the end of 2019. If you buy a phone you'll probably be limited to the apps it comes with, and any you do download probably aren't getting updates in the last few weeks of the app store's existence. You really will be throwing your money away.
If you don't want to buy Android, you're buying an iPhone -- the market is just that two-sided right now. You could try for a refurbished iPhone 8 if a new model is too pricey. There's also rumors of an iPhone 8-like "iPhone SE 2" (probably not the actual name) around March 2020 or so that would modernize things while keeping the price down to something like $399 US. Whichever one you get, the performance will be more than enough for what you're looking to do.
