Search In
  • More options...
Find results that contain...
Find results in...
Yuvraj Mann
is my 500w power supply enough?
Recommended Posts
Posted · Original PosterOP
is my 500w power supply enough for rx 5700xt oc? i'll be pairing it with i5 8400 along with 1ssd, 2hdd, 4 120mm fans and 1440p monitor
It will work fine, 550w is enough for a 9900k and 2080ti and you're way bellow that :)
Don't forget to quote (arrow bottom left of the message) or use name tag (@name) for us to see your answer.
My computer
CPU : I7-8700k  4,7GHz 1,275v | CPU cooler : Noctua NH-U14S | GPU : Sapphire Nitro+ Radeon RX Vega 64
Motherboard : Gigabyte Z390 Aorus Ultra | RAM : 32GB Corsair Vengeance RGB 3466 MHz CL16
SSD : Samsung 850 EVO-Series 500GB 2,5" + Sabrent Rocket 1TB M.2 HDD : Seagate BarraCuda 4TB 3,5" 5400RPM
Case : Phanteks ECLIPSE P600S Black | PSU : Corsair HX Platinum 850W
Others : Noctua NF-F12 PWM chromax.black.swap x3 top exhaust
Noctua NF-A14 PWM chromax.black.swap x3 front intake, x1 rear exhaust, x1 on the CPU cooler
Noctua NA-HC6 chromax.black on the CPU cooler
Wife Computer
CPU : R5 3600 4,2GHz 1,33v | CPU cooler : be quiet! Dark Rock 4 | GPU : Sapphire Nitro+ Radeon RX 580 8GB
Motherboard : MSI B450 Tomahawk MAX | RAM : 16GB Crucial Ballistix Sport AT 3200MHz CL16
SSD : Samsung 850 EVO-Series 250 GB 2,5" HDD : Western Digital Caviar Blue 1 TB 3.5" 7200RPM
Case : Fractal Design Define C TG | PSU : Corsair TXM 550W
yes
--------------------------------------------------------------------------------    Spec: Asus Vivobook S140UN    ---------------------------------------------------------------------------
| CPU: i5-8250U Turbo 3.4Ghz |
| RAM: 8 single-channel DDR4 2333mhz |
| Storage: 128GB Sandisk SSD + 1TB HTSG HDD
 | GPU: MX-150 4Gb 25 TDP |
| Monitor: LGMK430H-B |
| Audio: JBL 450BT Wireless Headset |
Depends of maker and model, if it's a good model then it's enough.
... but I'm no expert
What is your power supply?
The monitor has its own power supply which will plug in to the wall and doesn't consume any power from the computer power supply.
CPU: Intel i7 6700k  | Motherboard: Gigabyte Z170x Gaming 5 | RAM: 2x8GB 3000MHz G.Skill Ripjaws 5 | GPU: Gigabyte Aorus GTX 1080ti | PSU: Corsair RM750x (2018) | Case: BeQuiet SilentBase 800 | Cooler: Corsair H100i AIO | SSD: Samsung 970 Evo 500GB + Samsung 840 500GB | HDD: Seagate Ironwolf 8TB + 2x Seagate Ironwolf 6TB | Monitor: Acer Predator XB271HU + Samsung BX2450
this
2 minutes ago, Yuvraj Mann said:
this
(pic)
The lowest tier. Tier D
Suggesting to buy a better one. Like Corsair RM550x or something like that.
Remember back in the CRT and Windows XP days we still had this sort of thing? powering up the monitor directly from the power supply:
Oh the nostalgia~
Either ways, yes we know 500w suffices but asking what model it is specific is a must to cover all bases.
I found a mention of the TR2 S Power supply by @-The_Mask- at jonnyguru suggesting it is double forward design with group regulation which makes it to my understanding prone to coil whine when powering something like the 5700XT and it certainly isn't exciting.
About it being a safe bet or not though I'm not sufficiently experienced to say.
Workstation Rig:
CPU:  Intel Core i9 9900K @5.0ghz  |~| Cooling: beQuiet! Dark Rock 4 |~|  MOBO: Asus Z390M ROG Maximus XI GENE |~| RAM: 32gb 3333mhz CL15 G.Skill Trident Z RGB |~| GPU: nVidia TITAN V  |~| PSU: beQuiet! Dark Power Pro 11 80Plus Platinum  |~| Boot: Intel 660p 2TB NVMe |~| Storage: 2X4TB HDD 7200rpm Seagate Iron Wolf + 2X2TB SSD SanDisk Ultra |~| Case: Cooler Master Case Pro 3 |~| Display: Acer Predator X34 3440x1440p100hz |~| OS: Windows 10 Pro.
Personal Use Rig:
CPU: Intel Core i9 9900 @4.75ghz |~| Cooling: beQuiet! Shadow Rock Slim |~| MOBO: Gigabyte Z390M Gaming mATX|~| RAM: 16gb DDR4 3400mhzCL15 Viper Steel |~| GPU: nVidia Founders Edition RTX 2080 Ti |~| PSU: beQuiet! Straight Power 11 80Plus Gold  |~|  Boot:  Intel 660p 2TB NVMe |~| Storage: 2x2TB SanDisk SSD Ultra 3D |~| Case: Cooler Master Case Pro 3 |~| Display: Viotek GN34CB 3440x1440p100hz |~| OS: Windows 10 Pro.
HTPC / "Console of the house":
CPU: Intel Core i7 8700 @4.45ghz |~| Cooling: Cooler Master Hyper 212X |~| MOBO: Gigabyte Z370M D3H mATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: nVidia Founders Edition GTX 1080 Ti |~| PSU: Corsair TX650M 80Plus Gold |~| Boot:  SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~| Case: Fractal Design Meshify C Mini |~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro.
3 minutes ago, Princess Luna said:
  Reveal hidden contents
Oh the nostalgia~
this could be the reason of why my corsair vs450w fried on first day or a faulty product?
Corsair VS Series and now your TR2 S are both considered low end Power Supply units.
I would suggest against both line ups to power up a current generation video card like a 5700XT since these power supplies have old topology that simply doesn't meet the demands of the video card well enough to work optimally, and that's without going on the protections present on these products (or lack of).
Something like Corsair CX Grey Label units uses latest topology and are better value in the terms of reliability even if they cost a little bit more.
Workstation Rig:
Personal Use Rig:
Oh the nostalgia~
That is a direct pass-through straight from the cord coming from the wall , monitors have never used the computers PSU for it's own power. So the wattage on the PSU have never mattered for powering the monitor as it has it's own PSU. It was just a feature to have one less cable from the wall to your whole setup. Think of it like a power strip, one outlet from the wall connected to many different peripherals.
1 hour ago, Yuvraj Mann said:
this is what i could afford and purchased hope this'll do the job.
Nope. You just bought something worse than what you already had :) Good job.
(Why go through the effort of uploading an image here, instead of just telling us the unit's name?)
