Noise levels of case fans
Admire
Where do you find noise levels for case fans? Its pretty easy to find db levels for cpu fans or for GPUs under different kind of stress but I wanted to find out what noise different case fans make.
I am looking at cooler masters Storm Stryker, but could not find any noise levels from those fans.
The Mistress: Case: Corsair 760t   CPU:  Intel Core i7-4790K 4GHz(stock speed at the moment) - GPU: MSI 970 - MOBO: MSI Z97 Gaming 5 - RAM: Crucial Ballistic Sport 1600MHZ CL9 - PSU: Corsair AX760  - STORAGE: 128Gb Samsung EVO SSD/ 1TB WD Blue/Several older WD blacks.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103078
Those are the same fans if i'm not mistaken. Click Specifications and scroll down to see the noise level (16 DB).
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
Awesome! Thanks so much. That was what I needed. Well, 16DB, that is more than satisfying.
No problem =) The noise levels should be fine but that case comes with a fan controller so you can always adjust them if needed.
I know but i just wanted to find a reference point.
Don't trust their noise level specs. It's a sleeve bearing fan theyre noisy at low speeds. Get this fan instead http://www.newegg.ca/Product/Product.aspx?Item=N82E16835608037
I will probably get a noctua cpu fan but using brown case fans in a completely white case would be a crime against humanity.....
