Corsair Lighting Node Pro (or other hub) compatibility with LED strips
AlexQC
I was wondering if the Corsair Lighting Node Pro is compatible with third party LED strips. I'm asking because the LED strips that come with it are all 40cm and I need like 20cm max. I asked Corsair and their strips can't be cut.
If nothing is compatible with it which products (LED strips) are cuttable?
i don't no if you can cut corasir strips.
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
What are those pictures? I see at the end strips that are cuttable, but what are they and are they compatible with the Corsair Lighting Node Pro?
i posted a diagram on how to wire non corair argb strip like you asked. i also posted a pic of were to cut the argb strips and to show you what 30, 60, 144 led per meter look like. if you cant under stand it then your not ready  to do diy argb strips.
if your not in to soldering then there is a cable that is made for argb strips.
corsair 3pin or 4pin to jst-sm connector
Edited by thrasher_565
  • 9 months later...
Thanks for this, really helped with my first RGB setup.
  • 3 years later...
I followed the guide and it worked
I combine the corsair fans from the 4000x case + thermaltake fans (radiator)
note: it's necessary to set up with the corsair iCue software
