Search In
  • More options...
Find results that contain...
Find results in...
cliffjumpin
Will it fit? 2080 SUPER FTW3 HYBRID inside Lian Li PC-O11 Air?
Recommended Posts
Posted · Original PosterOP
Will the EVGA GeForce RTX 2080 SUPER FTW3 HYBRID GAMING fit inside the Lian Li PC-O11 Air? I am worried that the tubing will get in the way of closing the side panel, and even if it fits, will cause too much pressure on the tubing for the AIO cooler. It seems like there may be only 20mm for the AIO tubing to come out and around, between the edge of the actual card dimensions and the case side panel. Is that enough?
I all ready ordered both of these parts for my new build. Now I'm getting nervous about the GPU dimensions because I don't think they included the tubing coming out of the GPU. I looked up an equivalent air cooled EVGA RTX 2080 SUPER FTW3 and it had the exact same dimensions listed.
https://www.evga.com/products/product.aspx?pn=08G-P4-3288-KR
GPU: Dimensions Height: 5.48 in - 139.3 mm Length: 11.45 in - 290.83 mm Width: Dual Slot
PC-O11 AIR – LIAN LI
www.lian-li.com www.lian-li.com
Case spec for VGA Card: length ≤420mm , height ≤159mm
The motherboard height might affect the final fit, but I'm not sure how to evaluate it until I get the parts... I'm just wondering if I should return the case when I get it in the mail, or open it up and try the build to see if everything fits...
(Here is my parts list: https://pcpartpicker.com/list/BvpRsk)
if you are using watercooled parts, why did you buy the 011 air over the 011 Dynamic?
With no mods the dynamic is the better performing case even for air cooled builds. Mind you, the 'mod' is removing the mesh filter on the front panel, not like it's very intensive.
SenKa's Shop Thread: WIP
Brands I wholeheartedly reccomend (though do have flawed products): Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, CoolerMaster, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
Main PC: See spoiler tag
Laptop: Early 2014 Macbook Air. Intel i5-4260U, 4GB RAM, 128GB Apple PCI-E SSD, Intel HD Graphics 5000
Phones: iPhone XS Max, IPhone 6s x2, iPhone 5s. Lots more in parts.
CPU: Intel Core i5-8600K 3.6 GHz 6-Core OEM/Tray Processor  (Purchased For $200.00)
CPU Cooler: Corsair H50 57 CFM Liquid CPU Cooler  (Purchased For $0.00)
Motherboard: MSI Z370M GAMING PRO AC Micro ATX LGA1151 Motherboard  (Purchased For $120.00)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer  (Purchased For $75.00)
Monitor: Dell U2417H 24.0" 1920x1080 60 Hz Monitor  (Purchased For $0.00)
Monitor: LG 34UM69G-B 34.0" 2560x1080 75 Hz Monitor  (Purchased For $0.00)
Custom: Cooler Master Stacker 830 Evolution Nvidia Edition  (Purchased For $60.00)
Total: $1395.00
2 hours ago, Blai5e said:
@cliffjumpin - or maybe get a vertical mount kit for your case and the tube problem goes away (it is a 2 slot GFX card).
I heard a rumor that the vertical mounting kits introduce lag in first person shooter games, is this true ? If it's not going to cause delays or affect performance than I'm all for it. I believe this case actually comes with some kind of bracket for vertical mounting, and then I might have to purchase a connector? I don't know much about the vertical mounts.
I like the additional fan/radiator options on the O11 Air. I saw something about changing out the front intake filter on a GamersNexus video. What do you suggest?
Exactly what you said from GN
Useful threads:
Total: $1395.00
