Air Cooler for 9700K - Define Mini C
CrowDazzle
Hi All,
I just picked up a 9700K over the weekend and need some recommendations for an air cooler. I'm looking to build in a Define Mini C case and I currently have the Corsair Dominator Platinum RGB. The motherboard I'm shooting for is the MSI MPG Z390M GAMING EDGE AC. I don't plan on max overclocking it but I do plan on OCing it a bit for some extra performance.
Thanks!
Apple 2021 M1 Max MacBook Pro | Apple 2021 M2 MacBook Air
Intel Hades Canyon NUC - i7-8809G, 3.10 GHz | 32 GB RAM | 512 GB + 1TB Samsung 970 EVO | Radeon Vega GH | MSI Silent Armor 1060-6GB in Sonnet eGPU.
Intel Serpent Canyon NUC - i7-12700 | 32GB RAM
MSI MAG B660M MORTAR | Intel i5-12600K | EVGA 3080 Ti | 64GB Corsair Dominator | 2x2TB Samsung 990 Pro SSD | 4TB Samsung 870 EVO | 2TB WD Blue SATA SSD
Budget? On their site it says the maximum CPU cooler height is 172mm
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
Honestly any AIO that fits is fine. I’ve got my 9700k paired with an H80i V2, which is a thicc 120mm AIO, and the temperature never goes above the mid 70c in stress tests with only one fan.
Maybe in the $50 - $60  USD range. I feel anything over $80 I'll start looking at AIO's.
Thanks for the suggestion, that thing looks beefy.
Ouranos: https://pcpartpicker.com/product/skJkcf/reeven-ouranos-924-cfm-cpu-cooler-rc-1401
If you don't like the yellow, some good alternatives include
Ashura: https://pcpartpicker.com/product/GqTmP6/scythe-cpu-cooler-scasr1000
True Spirit 140 Power: https://pcpartpicker.com/product/qs6BD3/thermalright-cpu-cooler-truespirit140power
The Dark Rock 4 or NH-U12s would handle the 9700K well, but the fit might be a little tight in that case, because of the 170mm max height the Mini C allows. Because of that, the Dark Rock TF or the NH-C14s could probably be better options, since they are top flow coolers, eliminating a good chunk of the height, and also can cool the 9700K adequately.
If not, you could also go with something like a 120mm thick AIO, such as the H80i.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
I also got the meshify c and a 9700, non k though so no overclocking but i've been using the Hyper 212 black edition, it never goes above 65C when at full load and fits great in the case
Looks like a lot of great suggestions. Thanks for all the help and info everyone. ?
On 9/10/2019 at 2:33 AM, CrowDazzle said:
Hi All,
Thanks!
Look air cooling won't do it I had an air box cooler but all it did was overheat once I got an aio it was cool as hell. I would not recommend air cooling even a little bit
What do you mean by air box cooler? If you mean the Intel stock cooler, it's no surprise it'd overheat since it's not designed for the 9700k.
There are many, many examples of air cooling being perfectly suitable for the 9700k: https://pcpartpicker.com/builds/by_part/WtyV3C#qq=1
No u mean like a be quiet dark rock those type of box coolers lol I would never use a stock coolers I don't wanna kill my cpu
Pretty much any of be quiet's Dark Rock coolers will cool a 9700K more than adequately.
What about it? I have a Shadow Rock Slim which is the lowest end SKU of the Dark Rock line up cooling an i9 9900 and it is perfectly fine, temps on the mid to high 70's under full load sustaining 4.75ghz all cores.
Personal Desktop":
Luna, the temporary Desktop:
Well mine wasn't able to handle it even with thermal grizzly the i9s heat sink is terrible and hard to reach unlike other chips
Well idk I tried box fans and they did not do it for me at all the temps were high and even sometimes close to overheating
The Dark Rock series is the high-end whereas Shadow Rock is midrange. Pure Rock is entry-level. https://www.bequiet.com/en/cpucooler
There are plenty of things that could've caused high temps. Most likely, it was a lack of a power limit or some sort of auto-oc that's often set as default in the motherboard settings. It may have also been an improper mount or bad case airflow configuration.
What motherboard settings were you using?
default settings of the  meg msi z390 ace. I wasnt trying to overclock or anything just stock on everything.
There was probably some auto-oc'ing and / or raised power limit going on. You can see how the power draw compares to other motherboards with default settings. https://www.anandtech.com/show/13604/the-msi-meg-z390-ace-motherboard-review/5
Default motherboard settings is not the same as stock. It's increasingly common that it's already oc'ing out of the box instead.
