Is It Possible For a Router To Receive Connection Through Ethernet to USB Adapter?
Solved by SupaKomputa,
No, you need a driver for that adapter to work in a pc. I don't think the router has one.
But there's a workaround, if you install a custom linux rom (openwrt / ddwrt) it might support your adapter, some rom supports certain usb ethernet out of the box.
