PCIe power not connected, but it is.
ShawnC
I recently acquired a used EVGA GTX 1060 SC.
https://www.evga.com/products/specs/gpu.aspx?pn=5FA28D37-0FB1-42BE-8B9B-04223CB59D85
No matter what system it is put into it won't allow for booting because it throws the error that the PCIe power cable isn't connected.
I've tried 3 different systems and 4 different PCIe power connectors.
All the connector and traces visually look intact and unburned.
How can I further troubleshoot this card or do you all think I just need try to get it repaired\replaced via EVGA?
Sounds like a bad card truthfully if you've tried it in several systems and have the VGA power plugged into the card.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
  • 3 weeks later...
Yeah, ultimately I had to replace the card. EVGA wasn't very helpful in getting support in ANY way.
