hyperx Best HyperX headset (audio quality, comfort, mic quality)
Solved by Boinbo,
12 hours ago, Meenit said:Hello guys!
Title says it all, what is the best HyperX headset in terms of these 3 categories: Audio quality, mic quality, and comfort. If there aren’t any that are the best in all 3, then I would prefer them being the best in at least mic quality and audio quality.
Thanks!
Answering your question, the Hyperx cloud alpha. They are usually found cheaper than the cloud 2, and have better audio quality.
