fans Case Fans running at max Speed when gaming
Solved by Fluffy_1337,
3 hours ago, keskparane said:Something doesn't sound right.
These days some BIOS let you choose the sensor the fan reacts to. Perhaps you can set a different sensor?
Post your motherboard and BIOS ver for better help.
Hey man, thanks for the help but I found out the issue. I thought it was the power supply. But then after tearing apart the PC and playing while its guts were hanging out I noticed that it was actually the GPU. One of the three fans was being snagged by a 6+2 connector making the other fans go sicko mode. Pulled it out, played csgo for like 5 minutes and no issues. Once again I appreciate the helping hand.
