Search In
  • More options...
Find results that contain...
Find results in...
Plutosaurus
Think a be quiet pure rock slim will keep an i7-8700 non-k at Max boost?
Recommended Posts
Posted · Original PosterOP
4.3ghz without throttling?
Asking for a friend who is using a stock cooler.
My System: i7-8700k 5.0ghz delidded @1.355v // Cryorig H7 Quad Lumi // Gigabyte Aorus Z370 Gaming 5 // 16GB Corsair Vengeance DDR4 3200 // Sapphire Radeon RX Vega 64 UV/OC 1677core/1050hbm // NZXT S340 White // Seasonic Focus Plus Gold 850w // Intel 660P 1TB NVME M.2 SSD/120GB PNY CS900/480GB PNY CS1311/1TB Hitachi Deskstar // Displays: ASUS VG248QE/ASUS VG245H/ASUS VP248QG // Eagletech KG010 Mechanical Keyboard - Logitech G502
Wife's System: Ryzen 5 1600 3.8ghz // Wraith Spire // Gigabyte AX-370-Gaming // 16GB T-Force DDR4 2667 // XFX Radeon RX 580 8GB // Corsair Obsidian 750D // Seasonic Focus Plus Gold 850w // 120GB Sandisk SSD/500GB Silicon Power A55/4TB Western Digital Blue // Displays: Acer K242HYL/Acer K242HYL // Eagletech KG010 Mechanical Keyboard // Logitech G602
Son's System: i3-8350k 4.8ghz @ 1.35v // Cryorig H7 Quad Lumi // ASRock Z370 Extreme 4 // 16GB Corsair Vengeance DDR4 3200 // ASUS Radeon RX 570 4GB // NZXT S340 Black // Seasonic S12II 620w Bronze // 525GB Crucial MX300/500GB Wester Digital Blue // Display: Dell P2417H - Eagletech KG010 Mechanical Keyboard // Logitech G203
Daughter's System: i5-4570 // ASUS H81I-Plus // 8GB Corsair DDR3 XMS2 1333 // Zotac GeForce GTX 1060 3GB Mini // Cooler Master Elite 130 // Corsair CX600M // 120GB Sandisk SSD/500GB Western Digital Blue // Display: AOC 20" // HP Business Keyboard // HP Business Mouse
maybe? you will have to test it out. return it if it doesnt.
On 6/12/2019 at 10:21 PM, Den-Fi said:
-snip-
Sure okay but that doesn't have anything to do with my question
Oh right. I meant to give an actual answer along w/ the turtle meme.
There are a few things that need to be known. Does he have a board that supports MCE? Typical boost duration may not keep clocks there.
If it was something like an MCE equipped Asus board, then it should. If I remember correctly. Someone on here had their 8700 running 4.7 at all times w/ MCE.
Build Logs: Cotton Candy Threads | ZEN CLARITY + | Just NCASE mITX | Noc Noc | NUC | Storage Log
Cotton Candy Threads - CPU AMD Threadripper 2950X | GPU EVGA FTW3 RTX 2080 Ti | MOBO Asus ROG Zenith Extreme | MEMORY 128GB (8x 16GB) Corsair Vengeance RGB 3200 | STORAGE 3x Samsung 960 Evo SSD + 4x Crucial P1 1TB + 2x Seagate Ironwolf 8TB 7.2k HDDs | PSU Corsair HX1200i w/ Cablemod Pro Extensions | COOLING Cooler Master TR4 ML360 | CASE Lian Li O11 Dynamic Black | LIGHTING 2x Corsair HD120 Fans, 4x Corsair Addressable RGB Strips, 2x Corsair Commander Pro | PCPP
ZEN CLARITY + - CPU AMD Ryzen 2700X | GPU Radeon VII | MOBO Crosshair VII Hero | MEMORY 32GB (4x 8GB) Corsair Vengeance RGB Pro @ 3200 | STORAGE Samsung 960 Pro SSD + 2x SanDisk Ultra II SSDs | PSU Corsair RM1000i | COOLING Corsair H150i Pro | CASE Crystal 570X | LIGHTING 6x Corsair SP120 Fans, Cablemod Addressable RGB Strip, Corsair Commander Pro | PCPP
Just NCASE mITX - CPU Intel Core i7 8700K @ 5.2GHz | GPU EVGA RTX 2080 Ti XC | MOBO Asus Z370-I Gaming | MEMORY 16GB (2x 8GB) G.Skill Triden-Z RGB 3000 | STORAGE Samsung 960 Evo 500GB SSD + Corsair MX500 1TB M.2 SSD | PSU Corsair SF600 | COOLING Noctua NH-U9S w/ Redux Push/Pull Fans | CASE NCase M1v5 | LIGHTING 2x Cablemod Addressable RGB Strips | PCPP
Noc Noc, Who's There? - CPU AMD Threadripper 1950X | GPU ASUS RTX 2080 Ti OC | MOBO ASRock X399M Taichi | MEMORY 32GB (4x 8GB) GSkill Trident-Z 3200 | STORAGE Samsung 970 Evo SSD | PSU Corsair HX1000i w/ Cablemod Pro B&W Kit | COOLING Noctua U9 TR4 w/ 2x Redux 92mm | CASE Corsair 280X White | FANS 6x Noctua 140mm Redux | PCPP
it is an asrock z390m-pro4.
His throttles currently on the stock cooler to around 4.1-4.2ghz under load (should be 4.3ghz if thermally sound) and it is loud as FUCK.
So trying to get him set up with a cooler that won't be quite so noisy, allow him to keep max boost clocks, and also fit in his case (155mm max)
Yeah, it should be plenty for cooling.
Moved to Air Cooling.
You can setup manual voltage if temps are too high for your liking.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
