Looking for Power supply for RTX 2070
xReqt
Specs:
I7-8700
16gb 3000mhz DDR4
Prime z370-a
RTX 2070 Msi Armor
Corsair AIO H100x cooler
x3 fans.
I need a fully modular power supply/ one that would work with a RTX 2070 within 70 pounds on Amazon UK The faster the response the better as I'm ready to buy.
I'd like a 650W if possible. I cannot go over 75 pounds.
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
16GB DDR4 Crucial ram (2133mhz)
Prime Z370-A Motherboard
Gamemax Falcon (White)
Peripherals
Logitech G305
Corsair Strafe MX RED
Blue Yeti /w arm
JVC (Headphones)
Another £5 and you have a good good quality psu. Sorry don’t have a link as was searching via the app
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
Would a 550W power supply work no problem with a RTX 2070 i7-8700 for years?
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
i7 8700 + RTX 2070 system will need about 300-350w max. 550w will be plenty.
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
Heaps mate. 550w is plenty.
 Be quiet Pure power 11. Fits within your budget and decent enough.
still advise spending those extra £5 for a higher quality psu.
1 minute ago, xReqt said:
It'd be okay, but the RMx suggested earlier would be better. Probably a bunch of other stuff around the same price that would be a lot better as well, so I wouldn't recommend the EVGA B3.
This Pure Power 11 is cheaper and better than the EVGA B3
https://www.amazon.co.uk/BEQUIET-BN297-Semi-Modular-Bearing-Supply/dp/B07JHLD38L/ref=sr_1_2?keywords=pure+power+11+500w&qid=1560164531&s=computers&sr=1-2
@Spotty and @Stormseeker9 would this power supply work https://www.amazon.co.uk/BEQUIET-BN298-Semi-Modular-Bearing-Supply/dp/B07JK4DPJC/ref=sr_1_1?keywords=pure+power+11+600w&qid=1560165118&s=computers&sr=1-1 its the one you recommended but would a semi modular work? I thought It had to be a fully modular PSU for the 6-8 pin connectors for the RTX 2070. If you could answer soon as possible I will buy it np
Also doesn't the RTX 2070 MSI Armor overlock itself with a feature of Nvidas from 1400 to 1620 if so will it still be man enough to run it.
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
I run 2700x And 2070 of the Corsair RM550X I mentioned above. I can highly advise getting this same psu or similar.
@Spotty and I have linked various PSU’s. Like the be quiet pure power 11 (fits within your budget)
@Stormseeker9 ah thanks m8. But would a Semi modular psu work with a 2070? again this is the link https://www.amazon.co.uk/BEQUIET-BN298-Semi-Modular-Bearing-Supply/dp/B07JK4DPJC/ref=sr_1_1?keywords=pure+power+11+600w&qid=1560165118&s=computers&sr=1-1
And to my question about it auto overclocking as I've heard it does would it matter to the psu?
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
No... Doesn't need to be modular at all. Even PSUs with fixed cables should come with PCIe cables for the graphics card.
Amazon is annoying to browse for PSUs because they rarely list the product specifications properly for items; don't show information like what connectors it has. Means you have to search for it or look it up on the manufacturers website to find out what it has. What you're looking for are "6+2 PCIe" connectors to supply power for the graphics card. Most RTX2070 will require 8pin+6pin so you will require a PSU that has at least 2x 6+2pin PCIe connectors - which most decent PSUs have.
Here's the manufacturers website for the Pure Power 11 which has information on the models and you will be able to find their cable count information there. Just go to the Technical Data page and there's a photo there with the cables on it. https://www.bequiet.com/en/powersupply/pure-power-11/1532
I'd save the 10 pounds and go the 500w CM (Semi-Modular) version for 65 pounds. Or if you aren't fussed by semi modular cables you can get the 500w and 600w non-modular versions for 60 pounds.
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
Spend the extra £5. You don’t need full modular. The psu’s @Spotty and I have mentioned will all
work
as to the auto overclocking, think it’s called nvidia boost 3.0 and it basically overclocked itself if there is thermal headroom. Not much to do with the psu as such, but a shitty quality psu is never good for any system
No, won’t work. Only has 1 6+2 connection (of Amazon has put the correct pictures with the product)
Amazon must have wrong information (I did say earlier it was horrible for product specs!) The Corsair TX550M has 2x 6+2pin PCIe connectors coming off of a single modular cable. So it's one cable that splits off in to two connectors.
Edit: errhhh.... Corsair website is actually showing that the TX550M has 4x PCIe connectors. Wut?
Edited by Spotty
@Spotty and @Stormseeker9 I think i'm going with this one https://www.amazon.co.uk/BEQUIET-BN298-Semi-Modular-Bearing-Supply/dp/B07JK4DPJC/ref=sr_1_1?keywords=pure+power+11+600w&qid=1560165118&s=computers&sr=1-1 Does it have everything I need ( Connectors, Wattage , Lifespan) I will buy it straight away after the go from you two.
Btw thank you for all the help I am just getting into hardware and such and ive learnt nothing on PSU's yet so this is greatly appreciated!
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
Yeah, it'll work. Has all the cables you need, and double the wattage you really need (hence why I'd go the 500w CM instead and save 10 pounds).
Here's the cables that come with the BQ Pure Power 11 CM 600w.
https://www.bequiet.com/en/powersupply/1535
@Spotty and @Stormseeker9 Thank you so much for your help I am fussy when it comes to PC parts I think I know best when I probably don't lol. So i've got your 100% to buy this PSU and it'll work JUST fine.  Again thanks is there a way for me to upvote your accounts or something?
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
@xReqt
happy to help! Enjoy your new pc
