Need help with fan setup on Phanteks P350x
BurGym
I'm going to rebuild my PC in Phanteks P350x and I need some help with where to place my fans. Here are some of my fan setups:
First setup is 2 140mm intake fans in front (Corsair AF140 LED), 2 120mm exhaust on top (Corsair AF 120 LED if I keep the stock fan or Thermaltake Riing 12 LED if I don't keep it) and 1 120mm exhaust fan in the back (stock fan or Thermaltake Riing 12 LED)
Second setup is 2 140mm intake fans in front (Corsair AF140 LED), 1 120mm exhaust on top back (Corsair AF 120 LED if I keep the stock fan or Thermaltake Riing 12 LED if I don't keep it) and 1 intake fan in top front (Corsair AF 120 LED if I keep the stock fan or Thermaltake Riing 12 LED if I don't keep it) and 1 120mm exhaust fan in the back (stock fan or Thermaltake Riing 12 LED)
My question is "Which setup should I choose (or another setup) and should I keep the stock fan and save 10€?"
I'm new here and I think that I posted this in the wrong place. Is it possible to move it?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
1st setup is better. 2nd setup will create positive pressure and a lot of turbulence.
Main system: Ryzen 7 7800X3D / Asus ROG Strix B650E / G.Skill Trident Z5 NEO 32GB 6000Mhz / Powercolor RX 7900 XTX Red Devil/ EVGA 750W GQ / NZXT H5 Flow
-Moved to Cases and Power Supplies-
The first option is better to prevent turbulence (air just cycling between the top fans) I would make sure your front fans are spinning overall faster than your exhaust fans to help keep airflow either neutral or slightly positive
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
Thank you for the answer!
Just now, IAmAndre said:
I'm no expert but I understood that hot air goes up so the top fans should be used for exhaust
While it is true heat naturally rises through convection, it's nowhere near enough to have any when forced mechanically in any given direction
Quote
Given the results of this thought experiment, the results of our emperical testing are making a lot more sense.  Convection, while a strong concept in thought, simply does not generate the results necessary to play a discernible role in a typical chassis.
https://www.pugetsystems.com/labs/articles/Vertical-vs-Horizontal-Case-Cooling-89/page3
